DP Tuner and elevation...again... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 07-02-2008, 03:46 AM Thread Starter
Firehunter's Avatar
Hey, they had the tow programs listed seperately for below 4000' and above 4000' but now the list shows the tow programs are for both low and high elevation. What gives?
2000 F350 PSD, 4X4, CC, LB, 6-speed/ PHP Tuning /1.0 Turbo (no wastegate) with WW/ 4" turbo back exhaust/ AIS Intake with fender sleeve/ Isspro EV gauges/
Just because you can, doesn't mean you should!
Firehunter is offline
post #2 of 5 (permalink) Old 07-02-2008, 10:43 AM
SeeYa's Avatar
Re: DP Tuner and elevation...again...
We use to have them separated, but now there is no need to. Through testing Jody has found that you can use the settings set up for altitude for sea level, but couldn't use the programs set up for sea level for altitude. All the tunes are set up for altitude now. This is so you can use 1 tune for both and not have to buy 2, 1 for sea level and 1 for altitude anymore.
Diane
SeeYa is offline
post #3 of 5 (permalink) Old 07-03-2008, 02:53 AM Thread Starter
Firehunter's Avatar
Thanks Diane, that's what I was hoping for since I now live at 4900' elevation.
post #4 of 5 (permalink) Old 07-04-2008, 05:24 PM
So If I have a High Alt 60 tune I can use it without problems at lower altitudes?
2001 F-250 4x4 Crew shortbox, Optix gauges, DP F5 60towHighAlt, 80E, 100, 120. WW, ITP Boost Annihilator. DIY 6637 intake.
redmist is offline
post #5 of 5 (permalink) Old 07-05-2008, 11:35 AM
SeeYa's Avatar
Yes
SeeYa is offline
