exhaust leak? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 07-02-2008, 12:45 AM Thread Starter
Got Whistle?
crack_7.3's Avatar
exhaust leak?
i've got some soot inbetween the 2housings on my turbo, and noticed my EGTs are a little higher than usual, could this be the V band clamp since I just changed my turbo not to long ago?
08 F350 Lariat
Blacked
IDP tuned SCT
crack_7.3 is offline
post #2 of 5 (permalink) Old 07-02-2008, 02:16 AM
Mr. Bob's Avatar
Re: exhaust leak?
Where is the soot?? around the V clamp at the up pipes at the back of the turbo??? Or is it between the center cartridge and the exhaust housing???
1995 Ford F350 XLT CC LB, 4X4, 12V Cummins, ZF5, D60, Sterling 10.5, 6637 air filter, 7.3L Intercooler, Autometer Cobalt Gauges. ZF6 swap soon to come
Mr. Bob is offline
post #3 of 5 (permalink) Old 07-02-2008, 07:38 PM
NorCalDiesel's Avatar
Re: exhaust leak?
You should get a telescoping mirror and look behind the turbo at the y-pipe and housing interface, while you're at it look below the y-pipe at the donuts. If you have ever removed your turbo you may have pushed the y-pipe back and worked the donut seal(s) loose.
The housing fits pretty tight on the center section. If it is leaking there then all four of you housing bolts have to be loose. You would probably notice very poor performance at that time as well as the higher EGT's you are seeing.
2002 X PSD, Billy Boat 4", AirRaid, 38R,HO Outlet, IH Up-pipes, Gauges: Boost, EGT, Trans Temp, Fuel Pressure and Water Temp, Oil PSI at Turbo Pedestal
DP-Tuner 6 pos No Start - 140
Super Heavy Duty 4R100 / triple disc from ATO
Transmissions in Sacramento
ICON 5" Spring Pack Lift
PSC Ram Assist Steering
NorCalDiesel is offline
post #4 of 5 (permalink) Old 07-03-2008, 12:35 AM Thread Starter
Got Whistle?
crack_7.3's Avatar
Re: exhaust leak?
i havent really had a close look but where i can see it its on the center cartridge but I thinks its prolly from the up pipes or something like that, I cant see the turbo being loose?
08 F350 Lariat
Blacked
IDP tuned SCT
post #5 of 5 (permalink) Old 07-03-2008, 05:18 AM
Re: exhaust leak?
My money is on your donuts...
