How does everyone like there new scangauges? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 83 (permalink) Old 07-01-2008, 06:37 PM Thread Starter
So, what does everyone think and has anyone hooked the fuel pressure gauge to the back of the fuel bowl? Happy with the gauge? Thanks
2002 f-350 PSD, 4x4, cc short bed, 6spd, ccv mod, airdog, AIS filter, isspro ev and scangauges, detroit TT, ITP boost annihalator, ITP RR, bellowed up-pipes, ats housing, turbomaster, 3.5 dp magnaflow, very happy with ultra smooth and linear PHP 50t, 80DD and "whisper" tunes.
clydesdale is offline
post #2 of 83 (permalink) Old 07-01-2008, 07:04 PM
Smarty Power!
John_DeereGreen's Avatar
Send a message via AIM to John_DeereGreen Send a message via Yahoo to John_DeereGreen
Re: How does everyone like there new scangauges?
I'm curious to see the answers to this as well. I've got a 3 gauge pod and only 2 holes are filled...
Jarrett Matthew
04.5 QCSB auto common rail
Smarty TnT; ISSPRO PERFORMAX
Suncoast full billet
John_DeereGreen is offline
post #3 of 83 (permalink) Old 07-01-2008, 07:07 PM
Send a message via AIM to JohnT
I love my scan gauge! One of the best gauges I have. Its nice to be able to see all the parameters without my laptop. I don't have the fuel pressure gauge hooked up through the scan gauge since I already have an Autometer fuel pressure gauge.
99 PSD 4x4 CCLB
05 PSD 4x2 RCLB
JohnT is offline
post #4 of 83 (permalink) Old 07-01-2008, 07:20 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
I like it. Still playing with it a bit, but I think I will get one for the wifes Excursion as well but with the buzz and cont testing. Removed my Isspro HPOP gauge and installed it there. Watching ICP duty and pressure. Everything else I have covered...
Joe
CSIPSD is offline
post #5 of 83 (permalink) Old 07-01-2008, 07:48 PM
Ricky Bobby
JSlack's Avatar
What is this guage? does it plug into the OBDII and then scroll through perameters?
JSlack is offline
post #6 of 83 (permalink) Old 07-01-2008, 08:01 PM
racehauler's Avatar
http://www.aeroforcetech.com/Fordtech.html
You can have it scroll through paramaters if you want or you can have it just display 2 paramaters that you selected.
I've got one, I can't say it's the best money I've spent on my truck but it's for sure not the worst mone I've spent on it
I got it mainly for the code reading and CCT features.
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
post #7 of 83 (permalink) Old 07-01-2008, 08:02 PM
Yes is uses our ODBII port. I really like this gauge. Started using it at the track. Can see boost much better than my analog gauge as well can use the announcer to light up at preselected levels. Very nice.
NWSUPRD is offline
post #8 of 83 (permalink) Old 07-01-2008, 08:17 PM
thetonka's Avatar
How accurate is the boost guage using the factory MAP sensor?
2001 F350 CC LB 4X4
TN, AIS, DP 80hp, ITP boost elim, Magnaflow 4".
Tows the big white hauler.
When life gives you Lemons, throw them at the stupid people.
thetonka is offline
post #9 of 83 (permalink) Old 07-01-2008, 08:28 PM
racehauler's Avatar
Pretty close up to the point that the MAP sensor maxes out. That is around 23 to 27 psi depending on the sensor.
Mine maxes out around 18 due to the regulator in the map line for overboost protection. This would be the same for you since you have an ITP OBA also.
Any electronic overboost protection may make the readings inacurate.
Eric
96 F-350 CC Dually
post #10 of 83 (permalink) Old 07-01-2008, 08:38 PM
You can also get them through me, but it will have my logo instead of the Aeroforce logo.
http://www.terminatorengineering.com/scangauge/ (my logo not shown yet)
I have not hooked up my fuel pressure sensor yet either.
TerminatorEngineering is offline
