Optimal Fuel Temp - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 07-01-2008, 04:00 AM Thread Starter
A Ghost these days.
mad_matt's Avatar
Send a message via Yahoo to mad_matt Send a message via Skype™ to mad_matt
Optimal Fuel Temp
Ok so what is the optimal fuel temp for fuel in the PSD? I'd like to know the optimal temp for most complete combustion (Going after Mileage)and what temp yields the most power. I asked this question in the quad feed thread and it got lost. So what temp should the fuel int he system be so that it's perfect or as close to perfect in the fuel rail before it heads to the injectors bot best burn and most power ????
Got Boost?
Slightly modded 01 F350 CC SB 4X4
Powered by Oil driven by Madness.
Post Injector upgrade Spin: 577/944
Dynojet
HP: 597 BWD Superflow
13.152 @ 104.7 mph
Mods: Everything plus the Twins.
In the mail: Everyone's stuff but my own
Planned upgrades: sho mods!
mad_matt is offline
post #2 of 13 (permalink) Old 07-01-2008, 04:05 AM
cemeyer's Avatar
Re: Optimal Fuel Temp
I remember something on TDS years ago about what CAT used for their test cell engines. It seemed that it was stated that the temp they used was the best for mileage and power. Too bad I can't remember the number.
cemeyer is offline
post #3 of 13 (permalink) Old 07-01-2008, 04:06 AM
Banned
dennis at itp i think was doing some research on this subject, pm him
whiteduallyil is offline
post #4 of 13 (permalink) Old 07-01-2008, 05:20 AM
sandnut's Avatar
Dennis did some testing to see if dropping the fuel temp would help, here's the 3 pages I know of:
page 1
page 2
page 3
It's been a while since I read this, but if I remember correctly, he was seeing if adding fuel coolers would make a difference, and it didn't. I could be wrong though, it's been a long time since I read that.
02 CC 4x4. AFE stage 2, Magnaflow 4" exhaust, BTS tranny, live-tuned by Jody, AC singles, DI regulated return, Terminator HPOP, DR 4.5" lift & some other stuff...
sandnut is offline
post #5 of 13 (permalink) Old 07-02-2008, 02:29 AM
Body Type: MULE
CATdiezel's Avatar
Caterpillars SPEC is 60* F OPTIMAL---test cell---
2011- F250 PSD CCSB 4x4 HS PERFORMANCE Tuning DPF OFF EGR OFF TRUCK HAPPY DRIVER HAPPY
your #1 NON-Cult member of the USA Government JustinM.
CATdiezel is offline
post #6 of 13 (permalink) Old 07-02-2008, 02:43 AM
OEM Moderator
Tom S's Avatar
That must be the balance between best flow and density I guess.
Tom
Tom S is offline
post #7 of 13 (permalink) Old 07-02-2008, 02:44 AM
<----Colin Banks
mattymx's Avatar
I would have to think that it would be the coolest temp where it is most viscous with no sign of gelling. That way it is warm enough to inject and properly atomize. What temp that is, I dont know.
mattymx is offline
post #8 of 13 (permalink) Old 07-02-2008, 02:47 AM
Body Type: MULE
CATdiezel's Avatar
I posted what the optimal temp is above....Cat knows best atleast on how to test one that is.
There is indeed some science behind 60* F
post #9 of 13 (permalink) Old 07-03-2008, 04:29 AM Thread Starter
A Ghost these days.
mad_matt's Avatar
My problem with that temp is that is just not realistic in the real world. I wonder if Dave's idea of a AC condenser in the fuel tank might have some merit for summer time fuel cooling. I still think 60 deg F is low. I wonder what the upper range is where the fuel still have 90-99% of the optimal properties.
I guess I'm going to run up to the Drags on Empty and then fuel up with a full tank of nice cool 55 deg fuel @ the local truck stop before heading in to insure my fuel is as cool as it can be before I start running.
Got Boost?
Dynojet
13.152 @ 104.7 mph
mad_matt is offline
post #10 of 13 (permalink) Old 07-03-2008, 05:45 AM
Banned
I need to see a 7.3 running on an engine dyno at load and then start bringing in the warmer fuel watching power output.
I need an engine dyno I guess.
Charles is offline
