Twins back pressure - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 50 (permalink) Old 07-01-2008, 03:13 AM Thread Starter
Donkey pumper
HeeHaw's Avatar
Send a message via AIM to HeeHaw
Twins back pressure
okay i have a question about back pressure with twin turbos I thought every one said that with twins you should have half as much back pressure as boost, but wait the last two people i have heard talk about twins, were running more back pressure then boost, and i mean WOT I just need some education hear, as i never plan on running twins or even go past having more than a chip on my pick up, just curious
1964 706 IH with a 05 Cummins motor Smartyfied.
"I'm spitting in your face cause I'm a dominating you!" -Hank 3
HeeHaw is offline
post #2 of 50 (permalink) Old 07-01-2008, 03:15 AM
POWERSTROKER's Avatar
Re: Twins back pressure
Early 1999 (4/98) 7.3, Automatic, f-250 superduty, 4x4, crewcab, shortbed.
CCV Mod
knn intake
banks exhaust
banks power elbo
banks turbo housing
big head waste gate-disconnected
Tuning by
4 gauge pod with DiPricol pyro, boost, trans temp, HPOP
POWERSTROKER is offline
post #3 of 50 (permalink) Old 07-01-2008, 03:56 AM
A Ghost these days.
mad_matt's Avatar
Send a message via Yahoo to mad_matt Send a message via Skype™ to mad_matt
Someone mentioned something about positive cross over 2 me. I'm not convinced that it can be reached. I know that I get 1-1 or dam close to it for a good RPM/boost range but then things start to slide. I think that's why the move to VNTs has occurred.
Got Boost?
Slightly modded 01 F350 CC SB 4X4
Powered by Oil driven by Madness.
Post Injector upgrade Spin: 577/944
Dynojet
HP: 597 BWD Superflow
13.152 @ 104.7 mph
Mods: Everything plus the Twins.
In the mail: Everyone's stuff but my own
Planned upgrades: sho mods!
mad_matt is offline
post #4 of 50 (permalink) Old 07-01-2008, 04:04 AM
Laces Out
bigrpowr's Avatar
positive crossover has been accomplished.
08' F250 4x4 w/ 3:55's
bigrpowr is offline
post #5 of 50 (permalink) Old 07-01-2008, 04:05 AM
At full boost?
TerminatorEngineering is offline
post #6 of 50 (permalink) Old 07-01-2008, 04:15 AM
Laces Out
bigrpowr's Avatar
who is full boost?
bigrpowr is offline
post #7 of 50 (permalink) Old 07-01-2008, 04:38 AM
Proud PSN Sponsor
Deputydog's Avatar
Originally Posted by bigrpowr View Post
who is full boost?
820 HP on 05/19/12
Toll Free 866-379-8685
Deputydog is offline
post #8 of 50 (permalink) Old 07-01-2008, 04:50 AM
urbanwheeler's Avatar
im still trying to learn about turbo operation and theories but doesn't a lot of it have to do with the comp map? if you reach full boost while still within the comp map you will retain the 1:1 or close with the right setup. its when you bost past the map on the comp that you start seeing a higher back pressure ratios. correct me if im wrong.
'96 f-250, auto, shackle flip, solid axle, rsk, high/crossover steering, 3.73's, true trac's front and rear, trac bars, gt4202, 7.3 ic, idm mod, ccv mod, A1000, 4-line DIY Gen3, dual ipr's, casserly 350/200's, arp studs, 910's, pushrods, elec. fan, 2-stage nitrous, fluidampr.
[SIGPIC][/SIGPIC]
urbanwheeler is offline
post #9 of 50 (permalink) Old 07-01-2008, 04:59 AM
2Cruel
moremph's Avatar
most of the open pulling trucks i have dealt with run a higher boost presure then drive pressure. If your boost is lower then your drive you need to look at your turbo setup
Travis
MPH Enterprises
2L Motorsports
SWAMPS Extreme Powerstroke Performance
Powerstroke Everywhere
moremph is offline
post #10 of 50 (permalink) Old 07-01-2008, 10:47 AM
DZL JIM's Avatar
I was told you always need to be as close to 1:1 as possible, otherwise you're twisting your turbo shaft which can eventually snap from the strain...
DZL JIM is offline
