Some help with gauges. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 07-01-2008, 12:51 AM Thread Starter
Burger Flipper
I got my gauges, and before I mess up my a pillar,I would like some help. Anybody know a link to an install of the pillar over the stocker and cutting the holes and whatnot? or some pointers?
2000 F250 Lariat SC 4X4, aFe 2 PG7, MBRP 4" SS Duals w/muffler delete, Dipricol gauges, 203* T-stat and billet housing, Dieselsite Coolant filter, 6.0 intercooler...07 Harley Lights, 5K retro-solutions HIDs, ITP pre-pump kit, Harpooned, "The Cure"
J_F250 is offline
post #2 of 10 (permalink) Old 07-01-2008, 01:16 AM
bigd4me2's Avatar
Re: Some help with gauges.
I don't quite understand your question, i'm not meaning to be a smartazz, but you are supposed to just buy a new a pillar, with gauge pockets already in it. and you just yank on the old one to remove it. i don't think anyone here has cut holes in their oem a pillar to install gauges. do you need a link to buy the a pillar?
02 dmax cc dually 4wd "miss piggy" tow bitch, afe pr7, magnaflow, Kennedy lift pump, dual rail mount filters, PPE tunes
00 f350 srw rc=6100lbs
ats comp housing,bdp 1.0 exhaust,afe pr7,4in turbo back magnaflow,hx cross,di regulated return,bbha,dp hi,40,80e,120r,6.oh no cooler autometer gauges, dual rail mount filters
bigd4me2 is offline
post #3 of 10 (permalink) Old 07-01-2008, 01:22 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
I think he is talking about drilling the holes in the factory pillar to run the wires. Correct?
Joe
CSIPSD is offline
post #4 of 10 (permalink) Old 07-01-2008, 01:56 AM
loner1's Avatar
Maybe this link will be of some help.
http://www.dieselmanor.com/diy/PSD3-...73gauge-p1.htm
2003 7.3 PSD 2wd XLT super cab long box, drw, automatic trans. 410 gears, stock exhaust with muffler delete, F5 DP Tuner chip, ISSPRO EV gauges, AIS air box w/foam sleeve. Zoodad, ATS compressor housing, Prodigy brake controller. Cat ELC HD coolant, coolant filter.
loner1 is offline
post #5 of 10 (permalink) Old 07-01-2008, 02:00 AM
Don't EFN worry about it
Aljay's Avatar
I have a 3 gauge that lays over the factory one. I just set it on there and marked holes for push pins. I have had good luck with a 1/2 drill size or a smidge bigger hole kinda at the base of the bottom gauge pod on the OE piller. I like to hide all my stuff as much as possible.
Tuned by T Wildman
Aljay is offline
post #6 of 10 (permalink) Old 07-01-2008, 02:07 AM
yea buddy!
Stites02psd's Avatar
02 reg cab dually, stage 2's, Garrett bb,air dog 100,fancy new up pipes, aeromotive 1000, some cool lookin gauges, kewl lookin chrome flashy tip, 423.9/900 at the beaners dyno
1991 f-250, 15mpg
1994 2500, built 215,cam.. worst mistake of my life....wish i had my ford back
MOTIVATED BY THE HATERS
Stites02psd is offline
post #7 of 10 (permalink) Old 07-01-2008, 02:13 AM
<----Simply the best.
StrokerTurbo7.3's Avatar
Send a message via AIM to StrokerTurbo7.3
Basically the same thing I have done also. Maybe the SD are different
No longer a proud member of PSN.
StrokerTurbo7.3 is offline
post #8 of 10 (permalink) Old 07-01-2008, 01:18 PM Thread Starter
Burger Flipper
Yes the one I recieved goes over the stock one if I am understanding correctly. There are some "christmas tree" tabs to mount it to the stock one.
J_F250 is offline
post #9 of 10 (permalink) Old 07-01-2008, 04:49 PM
CSIPSD's Avatar
Pull your factory one, line the overlay on it drill a few small holes for the push pins, one at the top and bottom on each side and one in the middle...
You will also need to drill a hole thru the factory one for your wiring unless you can fish it thru the handle holes.
Joe
CSIPSD is offline
post #10 of 10 (permalink) Old 07-01-2008, 04:51 PM Thread Starter
Burger Flipper
I think I got it. Thanks
J_F250 is offline
