Need Help ASAP with Walbro install!!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 06-29-2008, 06:13 PM Thread Starter
POWERSTROKER's Avatar
Ok, got the stock fuel pump out, but the new walbro pump only came with 2 barbed fittings. the factory fuel line screwed right in the front of the pump, but how am I supposted to connect the back fuel line??? its a quick connect from the factory but the only fitting I have is the barb fittings, so whats the fix??
TIA
Early 1999 (4/98) 7.3, Automatic, f-250 superduty, 4x4, crewcab, shortbed.
CCV Mod
knn intake
banks exhaust
banks power elbo
banks turbo housing
big head waste gate-disconnected
Tuning by
4 gauge pod with DiPricol pyro, boost, trans temp, HPOP
POWERSTROKER is offline
post #2 of 18 (permalink) Old 06-29-2008, 06:21 PM
Haul_n_horses2's Avatar
Re: Need Help ASAP with Walbro install!!!
TIA
Put the OEM pump back in until you have the correct fittings to plumb it from the tank to the fuel filter housing?
2002 F350 Lariat CC 4x4 4.10 DRW, with "the ultimate towing setup!": Nov 30, 1999 engine with Fluidampr, Melling LPOP, 910 springs and ARP headstuds, DP-Tuner, DI regulated return, AC singles with 80% over EDM nozzles, BTS dual HPOP, H2e, Spearco 6.0 IC and BTS tranny .
Haul_n_horses2 is offline
post #3 of 18 (permalink) Old 06-29-2008, 07:12 PM Thread Starter
OEM pump is only putting out 25 PSI.
It looks like I could cut the quick connect off, then use the barb fitting it came with, but there isn't ebough slack in the fuel lines for that.
CCV Mod
knn intake
banks exhaust
banks power elbo
banks turbo housing
Tuning by
post #4 of 18 (permalink) Old 06-29-2008, 07:32 PM
Genius, when I drink
ditch_dawg's Avatar
Order one of these from Dennis!
http://www.itpdiesel.com/store.php?c...on=show_detail
'03 F250 CC
"Beer is proof God loves us and wants us to be happy" Benjamin Franklin
Originally Posted by golfer View Post
blip the throttle, and you just changed your "HPOP" oil
put that on youtube
ditch_dawg is offline
post #5 of 18 (permalink) Old 06-29-2008, 07:37 PM
Sponsor
airflo71's Avatar
Grab some extra fuel line at napa tee into it with a fitting and connect. Then when ya got time take the band aid off and re-do it right.
airflo71 is offline
post #6 of 18 (permalink) Old 06-29-2008, 09:12 PM Thread Starter
Thanks for the replies guys, the problem has been resolved.
Does 60-61 psi of fuel pressure sound about right???
CCV Mod
knn intake
banks exhaust
banks power elbo
banks turbo housing
Tuning by
post #7 of 18 (permalink) Old 06-29-2008, 10:02 PM Thread Starter
OK, just got back from a harsh test drive and the fuel pressure gauge flickers between 50-52 at idle, is this normal??
Also when I turn the key the fuel pressure quickly shoots up to about 53 PSI, then drops to about 40 while cranking, then holds 50-52 at idle....normal??
CCV Mod
knn intake
banks exhaust
banks power elbo
banks turbo housing
Tuning by
post #8 of 18 (permalink) Old 06-29-2008, 10:16 PM
PSN Mega Miler
crowz's Avatar
Alldata list it as :
Fuel pressure 51 psi +- 4 psi.
Key on engine running 40 to 60 psi.
Hope that helps.
2002 F250 SuperDuty Lariat PSD 7.3 Crew Cab 4x4 302,000+ miles.
, Valvoline Extreme Blue 5w40 Synthetic,
, Clifford Matrix 50.5x Alarm
, P3 Brake Controller, Swamps Injectors, PHP Tunes
crowz is offline
post #9 of 18 (permalink) Old 06-29-2008, 10:21 PM Thread Starter
Guess I'm in good shape then, thanks Crowz.
CCV Mod
knn intake
banks exhaust
banks power elbo
banks turbo housing
Tuning by
post #10 of 18 (permalink) Old 06-29-2008, 11:02 PM
Busy Busy
Marty's Avatar
Sounds perfect to me.
You could just get fuel line and use some fittings and hose clamps and that would work.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
