DP F5 Question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 06-28-2008, 06:45 AM Thread Starter
QUITTER :)
txpsd's Avatar
DP F5 Question
Hey all,
Just curious... I have a 4 pos F5 chip with the gauge pod switch and I was wondering if I were to put it in position 2 and then unplug the gauge switch would it still run fine and remember it was in position 2 even if/when i turn off my truck? Let me know!
Thanks!
2000 FORD F250 4x4 CC with !BTS TRANNY! BDP CR CUMMINS< 'Nuff Said.
BDP Nutt Swinger
txpsd is offline
post #2 of 4 (permalink) Old 06-28-2008, 06:59 AM
sled hauler's Avatar
Re: DP F5 Question
When the gauge switch is unplugged the chip goes to the stock program, or whatever is in position 1 (0)
97 CC LB, 3.55'S, H2E, AFE STAGE 2, AFE 4" EXHAUST, 250/200's, IDM MOD, FACTORY TECH MONSTER BOX TRANS, DP TUNER, SRP1, IC, REG RETURN, H2E, STUDS, COMP 910, GAUGES, 6.0 TRANS COOLER
2015 cclb platinum f350
sled hauler is offline
post #3 of 4 (permalink) Old 06-30-2008, 02:04 PM
Sleep well my brothers
yamt03's Avatar
Re: DP F5 Question
When it unplugged it goes to no start and you drive it very far at all,maybe 100 feet according to Diane at DP and the go pedel doesn't work either. When I first installed mine I guess it didn't have very good contact and one day on my way home I noticed that the F5 was not lit up and I had no go pedel at all and went maybe 50 feet before it died.
Early 99 CC DRW AFE, 4" MBRP,Autometer,6.0 trans cooler, ITP, DP Tuner and cupholder upgrade
Former U.S.A. Res. MP & proud of it!
2005 Dodge 4x4 5.9 With some stuff done to it.
"If you voted for Obama in 2008 to prove you're not a racist…you'll have to vote for someone else in 2012 to prove you're not an idiot."
yamt03 is offline
post #4 of 4 (permalink) Old 06-30-2008, 03:03 PM
SeeYa's Avatar
Re: DP F5 Question
I have sent a reply to txpsd's PM and thought I would also reply to this thread.
When you unplug the switch (whether it is the f5 EX remote switcher or the gauge switcher) from the cable it will go to position 0. When you plug it back up it will go back to the last program you were in.
Hope this helps...
Diane
SeeYa is offline
