Torque Converter Lockup Switch and LED - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 49 (permalink) Old 06-26-2008, 03:46 AM Thread Starter
Which wire is it that is grounded to lockup the torque converter? I've followed the main group of wires from the transmission over by the fuel pump and I exposed the bundle of wires.
1995, 7.3 Powerstroke, BTS Trans....Currently trying to put the truck back together after years of pulling parts off of it....
dslpowr is offline
post #2 of 49 (permalink) Old 06-26-2008, 03:59 AM
7.3 PSD Mythology Expert
Powerstroke Racer's Avatar
Re: Torque Converter Lockup Switch and LED
http://www.dieselinnovations.com/techfiles/tclockup.pdf
Purple with a yellow tracer.
David Lott
Experience is what you get when you don't get what you want!!!
No purpose no happiness, know purpose know happiness ---> Happiness is a direction not a destination.
Powerstroke Racer is offline
post #3 of 49 (permalink) Old 06-26-2008, 04:01 AM
Laces Out
bigrpowr's Avatar
DI's personal instructions worked awesome!! thanks david.
08' F250 4x4 w/ 3:55's
bigrpowr is offline
post #4 of 49 (permalink) Old 06-26-2008, 04:09 AM
Your welcome Mikey, but the thanks should actually go to Chris Muncy as he is the one that put all that stuff up on the website.
I sure do miss that guy.
David Lott
post #5 of 49 (permalink) Old 06-26-2008, 04:19 AM Thread Starter
Thats a good write up on it. I'm curious though how the LED functions. Does it just light up when the torque converter is fully locked? I followed the instructions and when I turn my key on the LED light goes on and only turns off when I turn my key off. I tapped into the Purple with yellow wire. Its one of the smaller gauge wires.....? Do I have the wrong wire?
dslpowr is offline
post #6 of 49 (permalink) Old 06-26-2008, 04:22 AM
If you have it wired correctly it should only come on when the TC is commanded to lock.
David Lott
post #7 of 49 (permalink) Old 06-26-2008, 04:25 AM Thread Starter
I'll go double check things. I've got a wire tied into the purple/yellow that goes to my black wire on the LED and the red wire on the LED to 12V power. I haven't put the switch on yet. I'll have to trace from the 12 pin conncector.
dslpowr is offline
post #8 of 49 (permalink) Old 06-26-2008, 04:32 AM
Put the truck in drive then hold the brake and flip the switch, if it bucks and dies you have it wired correctly.
David Lott
post #9 of 49 (permalink) Old 06-26-2008, 04:38 AM
<- Sums it up
strokin_early_99's Avatar
Ditto. I post the DI link to anyone looking for a TC lockup switch.
Early99 CC LWB 4X4
Updated B codes, Modded H2E, Big oil, half filled block, studded, John Wood 4R100. 232K miles
Tows like a champ!
"Damn Larry, he passed us like a freight train passing a hobo!"
--Lisa P.
Just sold to Larry
2-17-2019: 97 CC LWB 4X4 7.3 with full banks kit, John Wood E4OD. 139K miles
strokin_early_99 is offline
post #10 of 49 (permalink) Old 06-26-2008, 05:10 AM Thread Starter
My truck has three purple wires with yellow traces. I tried each one seperately to see if I could stall the motor but none wanted to kill the motor. I put it in drive and grounded it out. I found that with one wires the LED is off until I ground that purple/yellow and the LED lights up. But it won't do anything beyond that. I tried the blue/orange wire with no luck. I remember there was one blue with yellow tracer wire I didn't try. Who knows maybe I'm just color blind.
dslpowr is offline
