P0263 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 06-25-2008, 11:59 PM Thread Starter
P0263
Pulled this during a cylinder cont test today. Have already send messages to my tuner and performance guru. Anything I need to be concerned about? Mods on link in sig.
Thank you all as always.
Mike
NWSUPRD is offline
post #2 of 5 (permalink) Old 06-26-2008, 12:21 AM
SeeYa's Avatar
Re: P0263
asked Jody and he said y'all had the valve covers off when he was there. He said to double check the wires underneath the valve covers to make sure something didn't get unplugged to the harness. In my best southern voice-Something ain't jiving with the wiring.
Diane
SeeYa is offline
post #3 of 5 (permalink) Old 06-26-2008, 12:28 AM Thread Starter
Re: P0263
Thank you Diane and Jody, there was a lot going on at the tuning event. John and I had the valve covers off when whe installed the injectors prior to the event. I will pull the driver side and check the connections tomorrow.
Thank you!
NWSUPRD is offline
post #4 of 5 (permalink) Old 06-26-2008, 10:24 AM
Haul_n_horses2's Avatar
Re: P0263
Thank you!
My DTC reference says Cylinder 1 is the culprit. Might have a hard time finding it under the driver's side valve cover.........
2002 F350 Lariat CC 4x4 4.10 DRW, with "the ultimate towing setup!": Nov 30, 1999 engine with Fluidampr, Melling LPOP, 910 springs and ARP headstuds, DP-Tuner, DI regulated return, AC singles with 80% over EDM nozzles, BTS dual HPOP, H2e, Spearco 6.0 IC and BTS tranny .
Haul_n_horses2 is offline
post #5 of 5 (permalink) Old 06-26-2008, 01:49 PM Thread Starter
Re: P0263
Thanks for the help, Diane, Jody and Haul n horses2. I am hoping a connection is loose and an easy fix. We replaced the wiring harness when we put in the injectors on this side.
NWSUPRD is offline
