Quick help for 3 gauge overhead pod install - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 06-24-2008, 03:13 AM Thread Starter
Wink Quick help for 3 gauge overhead pod install
Hey everyone,
I'm leaving tomorrow for BTS!!!!! In preparation for all the work I'm having done, I'm trying to install the 3 gauge pod that goes over the rear view mirror. The installation instructions don't mention removing the mirror to install the pod. In fact, their picture shows the mirror much lower than my truck's mirror.
Any of you out there in PSN land install this pod, and did you have to remove the mirror? If so, how does it come off.....I don't see any set screws. Thanks as always! V/r Les
USAF CCM is offline
post #2 of 7 (permalink) Old 06-24-2008, 03:16 AM
2nd class citizen
1snotrocket's Avatar
Re: Quick help for 3 gauge overhead pod install
i installed the 2 pod cleared the mirror no problem. just take a small screwdriver and pop the 1/2 round clip off front of mirror mount and remove the mirror. then mount the pod and re install the mirror.
2003 CRW CAB LB 4X4 6SPD,AFE STAGE 2,38r,DP TUNER,4'' MBRP,FASS 15,Farmers Disel Performance 160/100 injectors,ITPREG.RETURN,TERMINATOR
2001 crw cab short bed auto 4x4 5"exhaust afe stg 2,f6,jw trans,terminator,cass. stg2's,itp reg return,fuel lab pump.
1snotrocket is offline
post #3 of 7 (permalink) Old 06-24-2008, 03:24 AM
OEM Moderator
Tom S's Avatar
I have had to move that glued on mount for the mirror before. Gentle heat and a cresent wrench works if it hoses up your pod location
Tom
Tom S is offline
post #4 of 7 (permalink) Old 06-24-2008, 03:29 AM
Village Idiot
southmike's Avatar
if you have to move it.
be carefull it can bust your glass if you hurry.
but ost parts places carry that kind of glue
southmike is offline
post #5 of 7 (permalink) Old 06-24-2008, 03:41 AM Thread Starter
Great input, thanks guys. Out of three forums I visit, PSN was the first and only one to respond. AGAIN THANKS! V/r Les
USAF CCM is offline
post #6 of 7 (permalink) Old 06-24-2008, 03:45 AM
Banned
Send a message via Yahoo to blk99
maybe that means we have no life! jk
blk99 is offline
post #7 of 7 (permalink) Old 06-24-2008, 02:30 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
If you have a 03 and up, 99&#37; of the time your fine.
below that its hit and miss.
The windshields that say superduty across the top are 99% good to go.
Joe
CSIPSD is offline
