PCM CODE - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 06-23-2008, 11:05 AM Thread Starter
Old But Sexy
96 stroker's Avatar
PCM CODE
is there anywhere i can give the VIN and they tell me what pcm is in there. its for my dads 01 excursion. but hes not home right now and im tryin to get a chip he just bought used reburnt for him
96 F-350 CCLB ,auto with a couple 6 inch black aussie stacks, A Dp-tuner and AD injectors 66mm turbo and BD t.c...
Dads-01 7.3 4x4 Excursion..stock as could be
96 stroker is offline
post #2 of 7 (permalink) Old 06-23-2008, 11:33 AM
Banned
Re: PCM CODE
Take a 7mm socket or nutdriver and remove the bolts that hold the little black PCM case to the kick panel out, remove the case and see for yourself. Sometimes you have to use a long screwdriver down the driver's side of the case to pry the little plastic rib out of the back that holds it. (Grind this off while it's out).
You'll have to get to know how to do this in order to install the chip anyway. Takes all of 5 minutes even if you've never done it before. And it's the only way to know for sure what you've got. There's always the chance that the PCM has been changed for various reasons. My Vin would tell you that I have an AWA3 PCM, yet I have a DAC3 instead.
You can probably find instructions on removing the PCM from whomever you're getting the chip from. And just to see the cache code you don't even have to unplug the harness or actually remove the PCM, just the cover so that you can see the end plug where it's written.
Charles is offline
post #3 of 7 (permalink) Old 06-23-2008, 11:53 AM Thread Starter
Old But Sexy
96 stroker's Avatar
Re: PCM CODE
ok. hes not home right now. so i figured i'd see if i could see. and i did the dp tuner on my truck i kind of have a idea on how it works
post #4 of 7 (permalink) Old 06-23-2008, 11:55 AM
Banned
Re: PCM CODE
Good Luck.
Charles is offline
post #5 of 7 (permalink) Old 06-23-2008, 03:21 PM
Village Idiot
southmike's Avatar
Re: PCM CODE
go to dp-tuners web site he has some pointers , and some good chips too
. if your lucky you can get to it with a mirror but a lot harder to read..
also make sure your keys are no where near the ignition when messing with the pcm.
southmike is offline
post #6 of 7 (permalink) Old 06-23-2008, 03:29 PM
SeeYa's Avatar
Re: PCM CODE
Yes. Should be a DPC-452 PCM, but it's according to the build date.
SeeYa is offline
post #7 of 7 (permalink) Old 06-23-2008, 03:37 PM
Banned
Re: PCM CODE
As long as it's never been changed.
Charles is offline
