Tapping for boost and MAP - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 06-22-2008, 11:09 PM Thread Starter
I have my boost gauge and MAP sensor tapped on the turbo side of the IC right now. It seems to have better response vs. tapping after the IC. I teed the line and run my boost gauge as well.
Is it better to run the boost gauge after? You would see the pressure after the drop from the IC if there was any.
99 F350 CCLB
skav is offline
post #2 of 4 (permalink) Old 06-22-2008, 11:20 PM
7.3 PSD Mythology Expert
Powerstroke Racer's Avatar
Re: Tapping for boost and MAP
Yes, you could tell what the pressure drop was by checking it on both sides.
As far as what side you run it on will be determined by what you want to see.
I always install them in the MAP sensor line.
David Lott
Experience is what you get when you don't get what you want!!!
No purpose no happiness, know purpose know happiness ---> Happiness is a direction not a destination.
Powerstroke Racer is offline
post #3 of 4 (permalink) Old 06-23-2008, 12:05 PM
JimTJr's Avatar
I had mine on the Map line "T" ed into the tube on my 99. On this 03 I have it tapped into the spyder on the cold side of the CAC, boost NUMBERS seem lower, but are more accurate I would assume. (You are seeing the actual pressure going INTO the motors heads) Is there a RIGHT OR WRONG way? Not really. Heck I was on these websites for quite a while before I heard of anyone tapping their Intercooler spyder. It mostly started when people wanted to eliminate the intake heater. I think.
And David is happy with it going to the map sensor still, what ever works for you!
JimTJr is offline
post #4 of 4 (permalink) Old 06-23-2008, 01:16 PM
fbilly420's Avatar
I have my T'ed into the map sensor line as well. I just like to see what is going to the motor and not what the turbo is making.
2001 F250, CCSB, 4X4, Auto, Forged rods
Lots of go fast parts and still slow.
2001 F250, STD cab, 2WD
Frame is a little shorter now
workin on body
engine build underway
fbilly420 is offline
