You asked for it Kenny! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 43 (permalink) Old 06-22-2008, 06:31 AM Thread Starter
Busy Busy
Marty's Avatar
Worked on the truck all day yesterday to get it ready to pull. Finished stack, made some clamps and clamped the rear springs, got a hitch, and a few other odds and ends.
I ran the modified class which consists of basically 600+ hp trucks which 98% of are manuals. I pulled 283 feet, beat a few dodges, the other powerstroke and I don't think there were any Dmax's in the modified class (a lot in the stock, but not modified). There were less then 20 in my class... didn't finish in the top 3... don't really know where I finished but I was happy. This was my first pull ever! :)
Next time, now that I know they're going to bump me into a modified class (my turbo is 2.4 and the limit in the stock class is 2.5) I'll be bringing a lil more fuel to the table!
Anyway... here is the pull.... Started in 1st which just pulled right through the brakes (never spooled in 4x4 low b4) and when I shifted to 2nd it was a lil bouncy. Let out of it, corrected, and then hammered down again. Smacked the limiter and started pulling good and the brakes came on!
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #2 of 43 (permalink) Old 06-22-2008, 06:37 AM
Banned
Send a message via Yahoo to blk99
Re: You asked for it Kenny!
Looks awesome!!!!
blk99 is offline
post #3 of 43 (permalink) Old 06-22-2008, 06:39 AM
RedMule's Avatar
Nice!!
01 F250 CC SRW LWB,GTP 38 BB, Stage II's, HPX,AFE stage II, In tank & pre pump mods, 4" Turbo back.
New motor with forged rods,all balanced,comp 910's,CM pushrods,new valves,ARP Studs .DI reg return.New tranny also.
RedMule is offline
post #4 of 43 (permalink) Old 06-22-2008, 07:04 AM
Supercharged
Rockrunner86's Avatar
Send a message via Yahoo to Rockrunner86
Is it easier to pull with a auto or manual?
99.5 F-350 6-speed Daily Driver/Tow Rig.
Engine - Empire Diesel Performance
Air - Empire Diesel Performance Compounds Procharger Primary / Garrett 38R Secondary
Oil- Swamps Gen-3
Fuel - B-codes
Rockrunner86 is offline
post #5 of 43 (permalink) Old 06-22-2008, 07:09 AM Thread Starter
Busy Busy
Marty's Avatar
Well some say you have an edge w/ a manual, but I have an auto and it was basically pick the gear and floor it, and then make sure you don't bounce!
Elkton, Maryland
Marty is offline
post #6 of 43 (permalink) Old 06-22-2008, 01:17 PM
<<<<< Next Generation
boggerr's Avatar
Looks and sounds great.
Nice job Marty.
See you at Cecil
N.E. Terminator Tech
2000 F350 Lariat CC 4x4 LWB Auto
DP-Tuner F5, Terminator HPOP, QSSB, ITP's fuel system, BTS trans.
boggerr is offline
post #7 of 43 (permalink) Old 06-22-2008, 04:09 PM
King Dingaling
TANK'S 250's Avatar
In the second pic,..the one with both trucks...let him know his fuel door is open,...
Probably too late now though....lololololololol
TANK'S 250 is offline
post #8 of 43 (permalink) Old 06-22-2008, 04:47 PM
2010 BOB Points Runner up
Dieselfever's Avatar
Send a message via AIM to Dieselfever Send a message via Yahoo to Dieselfever Send a message via Skype™ to Dieselfever
If your inducer is in fact 2.4 and the class was 2.5, then you should have been able to pull in it. More fuel won't do squat, since your limit is the amount of air you can get into the engine. More fuel my actually hurt it.
Although depending on your 'stock' class a Dmax w/ the right supporting mods would most likey dominate that class. Same with a properly built dodge in the 'Pro' class or whatever they call it.
-Michael
Michael
1997 F350: Regular cab XLT, 7.3L PSD, 5 speed, 4x4, 3.55 - Some Stuff
2000 F350: Crew Cab, Lariat, 7.3L PSD, 6 speed, 4x4, 3.73 - More Stuff
2001 VW Golf: 4 door, GLS, 1.9L TDi, 5 speed - Darn near makes fuel!
Dieselfever is offline
post #9 of 43 (permalink) Old 06-22-2008, 05:16 PM
OBS junkie
Cat_Rebel's Avatar
I've heard that the manual can give you an edge or you can nuke the clutch if you don't get off the line right. Seen both do good though, look at what House's Dually can do!
By the way nice job Marty!
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #10 of 43 (permalink) Old 06-22-2008, 05:32 PM
Village Idiot
LRTMatt's Avatar
I saw the pull in person. Not bad for the first time out! Not much smoke, I suspect the DP switch had a few notches left on her. Truck behaved well and didn't do anything violent. A little more fuel next time and you will easily make up the 20' you needed to be in the competitive pack.
LRTMatt is offline
