H11 install - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 06-21-2008, 08:22 PM Thread Starter
Going Crazy
badluck_early99's Avatar
Send a message via MSN to badluck_early99
H11 install
So i got my studs here just dont know what the proper procedure is for torque.. and do i torque the actual studs?? I know ARP does but i thought i heard these dont..?
1999 F250 PS 6spd, 37x12.50x17 ProComp Xmud, 06 Grill & Lights. DP tuner, Terminator Hpops, Garrett 42, Casserly B codes, FASS Fuel system by DI, H11's, ITP Reg Return W/Bowl Delete, Sknab 6oh Intercooler, DIY Intake, 4'' Exhaust, Itp OBA, Autometer boost and pyro, , ccv
-Richard-
badluck_early99 is offline
post #2 of 10 (permalink) Old 06-21-2008, 08:56 PM
Re: H11 install
The studs just need to be screwed in to the proper depth with a slight preload and the nut should be torqued. If you are doing the change one bolt at a time method pull a bolt out, put a stud in and torque it then move on to the next one.
69W900A is offline
post #3 of 10 (permalink) Old 06-21-2008, 09:10 PM Thread Starter
Going Crazy
Re: H11 install
so what is the proper depth to get them to?
-Richard-
post #4 of 10 (permalink) Old 06-21-2008, 09:11 PM
Re: H11 install
Don't know what the instructions say - never read 'em, but probably something to the effect of lightly seated.
69W900A is offline
post #5 of 10 (permalink) Old 06-21-2008, 09:53 PM Thread Starter
Going Crazy
Re: H11 install
lol well i dont have instructions and dont really have any idea where to find them lol
-Richard-
post #6 of 10 (permalink) Old 06-21-2008, 10:13 PM
7.3 PSD Mythology Expert
Powerstroke Racer's Avatar
Re: H11 install
A1 H11's have a dog point on them, make sure the holes are clean and run them down till they stop then tighten them down enough to make sure they are seated well.
When I used them I took them to 140 final torque.
are they new or used?
David Lott
Experience is what you get when you don't get what you want!!!
No purpose no happiness, know purpose know happiness ---> Happiness is a direction not a destination.
Powerstroke Racer is offline
post #7 of 10 (permalink) Old 06-21-2008, 10:43 PM Thread Starter
Going Crazy
Re: H11 install
They are used a few weeks... should I just follow the APR Sequence and #'s other than just running them down?
-Richard-
post #8 of 10 (permalink) Old 06-22-2008, 10:45 PM Thread Starter
Going Crazy
Re: H11 install
BigityBump....... Anyone know how deep these lil basturds need to go lol ??
-Richard-
post #9 of 10 (permalink) Old 06-22-2008, 11:02 PM
Busy Busy
Marty's Avatar
Re: H11 install
Well I think I tightened them down to around 30 ft/lbs w/ the allen key and then torqued to a final torque of 135 or 145.
Retorqued after it got hot and nothing had changed.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #10 of 10 (permalink) Old 06-22-2008, 11:04 PM Thread Starter
Going Crazy
Re: H11 install
ok ill just do that then it sounds like a resonable number on the allen key part
-Richard-
