Does anyone have any dyno comparisons? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 06-20-2008, 06:52 PM Thread Starter
matthewd11's Avatar
I'm looking for dyno comparisons between the grey and black cps. I heard rumor that the black will add more fuel on the top end and the grey has a stonger mid-range. Is there some truth to this or myth? I am curious if anyone has any dyno numbers or track numbers to compare.
matthewd11 is offline
post #2 of 9 (permalink) Old 06-20-2008, 06:59 PM
Ricky Bobby
JSlack's Avatar
Re: Does anyone have any dyno comparisons?
isnt the cps just there to make sure the motor is turning, and to send a signal to the tach? thats all i thought it did...but i may be wrong...
JSlack is offline
post #3 of 9 (permalink) Old 06-20-2008, 07:00 PM Thread Starter
matthewd11's Avatar
Yes, its what tells the computer when to inject the fuel into a certain cyinder at a certain time. But i heard some rumor between the two sensors. Maybe charles or someone can give some input?
post #4 of 9 (permalink) Old 06-20-2008, 07:08 PM
fueled by Colecovision
golfer's Avatar
Garage
The CPS cannot affect injector on time, or pulse width.
The blue CPS retards injection timing 4degrees compared to the black CPS.
Meaning that if your tuner chose 14deg advance at a particular point in the fuel map, then (if you had the blue CPS) you would actually be running 10 degrees of advance.
Conversely...
If your tuner MADE the tunes ON a truck with a blue CPS...and injection timing was set at 14deg BTDC...then that same program, on the same truck with a black CPS would be running 18 deg advance.
take care~
Dave
golfer is offline
post #5 of 9 (permalink) Old 06-20-2008, 07:21 PM
Ricky Bobby
JSlack's Avatar
interesting..learn somthing everytime i click the left mouse button..lol
JSlack is offline
post #6 of 9 (permalink) Old 06-20-2008, 07:43 PM Thread Starter
matthewd11's Avatar
Conversely...
take care~
Dave
So there is no difference between the black and grey cps? Those rumors are not true? I wasnt refering to the blue one at all.
post #7 of 9 (permalink) Old 06-20-2008, 07:50 PM
DI POWER
joediesle's Avatar
There was a recall on the grey cps, it will create a miss and fail a contribution test showing #8 cyl failing. Stick with the black one.
01 250 sc xlt -" Forged Rods," Full Force 238/100s inj, Reg kit, Big fuel,DP F5 tunes, ATS BB turbo, ARP Headstuds, Com 910s, DI Pushrods, IDM mod, AFE Stage 2, TE2 HPOP R-IPR, BTS Trans, 6.0 intercooler, Fluidampr, HX, Cool max trans cooler, 4''exhaust & MORE.
joediesle is offline
post #8 of 9 (permalink) Old 06-20-2008, 07:54 PM Thread Starter
matthewd11's Avatar
Yeah i just got one from napa works fine, leaving the grey one in the glovebox. I was just curious about those rumors.
post #9 of 9 (permalink) Old 06-20-2008, 11:01 PM
Laces Out
bigrpowr's Avatar
i dont think there is any difference
08' F250 4x4 w/ 3:55's
bigrpowr is offline
