Stacking Chips - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 06-20-2008, 05:08 AM Thread Starter
spb_2006's Avatar
Stacking Chips
Ive got the Ts performance 6 position chip right now and i talked to a guy at a performance shop that said i could put the edge programmer that adds 75hp to that. He said everything would hold up except maybe my clutch, ive got the 6 speed. HAs enybody tried or heard about this? Ive got the exhuast and intake covered with stacks and afe intake.
spb_2006 is offline
post #2 of 22 (permalink) Old 06-20-2008, 05:17 AM
OBS junkie
Cat_Rebel's Avatar
Re: Stacking Chips
No you can't to put it simply. Nore would you want or need to. I think the TS would also over ride the EDGE since your TS plugs right into your PCM. Pull it off & send it to Tony Wildman & he can put new tunes on it for you. It will make a diffrence over the TS.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #3 of 22 (permalink) Old 06-20-2008, 05:32 AM
urbanwheeler's Avatar
Re: Stacking Chips
like cat said, if you send it off to tony or jody they can put some new tunes on it. stacking chips is a waste of money, unless you are doing an evo/ez stack but is it far more economical to get a custom chip done. just my .02, i have run them all.
'96 f-250, auto, shackle flip, solid axle, rsk, high/crossover steering, 3.73's, true trac's front and rear, trac bars, gt4202, 7.3 ic, idm mod, ccv mod, A1000, 4-line DIY Gen3, dual ipr's, casserly 350/200's, arp studs, 910's, pushrods, elec. fan, 2-stage nitrous, fluidampr.
[SIGPIC][/SIGPIC]
urbanwheeler is offline
post #4 of 22 (permalink) Old 06-20-2008, 06:00 AM
OBS junkie
Cat_Rebel's Avatar
Re: Stacking Chips
Dodge Cummins can & are made to be stacked. The 7.3L is great since we can get a tune on the fly chip plugged right into the PCM.
RIP Will Iott
post #5 of 22 (permalink) Old 06-20-2008, 02:13 PM
<-- it's like that
Re: Stacking Chips
The reason they don't stack is because a chip plugged into the back of the PCM overrides whatever is programmed onto the PCM. The Edge unit programs the PCM, so it will be pointless and will not stack.
Stacking is old school technology for these trucks. Back when performance products first came out, no one had a single chip to control fueling, timing, oil pressure, trans line pressure, etc. So multiple boxes were built to control all of these, hence the "stacking". Today's chips from TS, Tony, Jody, etc control everything, so stacking is no longer necessary. Only Edge and Banks continue to provide stacking units, simply because it turns higher profits for them.
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's.
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the
Pocket is offline
post #6 of 22 (permalink) Old 06-20-2008, 02:49 PM
fbilly420's Avatar
Re: Stacking Chips
Your money would be better spend on one good chip with custom tunes.
My .02
2001 F250, CCSB, 4X4, Auto, Forged rods
Lots of go fast parts and still slow.
2001 F250, STD cab, 2WD
Frame is a little shorter now
workin on body
engine build underway
fbilly420 is offline
post #7 of 22 (permalink) Old 06-20-2008, 11:35 PM
Sponsor
VanAackenBrosRacing's Avatar
Send a message via AIM to VanAackenBrosRacing
Re: Stacking Chips
One good chip and thats all you need! stacking will hurt you!
EMPIRE DIESEL PERFORMANCE OF DUBUQUE IA
Procharger kits for 6.0 and 7.3 powerstroke and LBZ/LMM NOW TAKING ORDERS!
Procharger Cummins kit in R&D
Billet Camshafts w/Custom Firing Order for Duramax Smooths dmax harmonics to prevent #2 journal crankshaft failures in high HP builds.
Precision Turbos Custom 2.6, 2.8, 3.0 billet chargers
VanAackenBrosRacing is offline
post #8 of 22 (permalink) Old 06-20-2008, 11:36 PM
Drink til she's cute
Thuglike's Avatar
Re: Stacking Chips
X3
2008 F-250: High Powers / Dual K16 / 60% Nozzles
ELITE
NO LIMIT
SWAMPS
GEARHEAD
INNOVATIVE
Thuglike is offline
post #9 of 22 (permalink) Old 06-21-2008, 11:30 PM
rocketron's Avatar
Re: Stacking Chips
Stacking chips? Don't they call those Pringles?
2001 F-350 XLT Super Cab 6 Speed. DP tunes (40t, 80e, 120r, hi idle), Overboost Reg, Tymar,4" AFE exhaust, Autometer Guages, Pro Comp leveling kit, 315/75-16 Toyo mt, American Racing wheels, other stuff coming!
"Duramax and Tampax, they're both for Pu$$ys!"
rocketron is offline
post #10 of 22 (permalink) Old 06-22-2008, 12:22 AM
STC73's Avatar
Re: Stacking Chips
I have the Edge Juice w/ Attitude stacked and i havent had a single problem... (yet) Soon as i can save up the money im getting Isspro gauges and a DP tuner. Ive heard its the best of the best. It will work stacking them but i recommend doing it right when i got these chips they didnt have that stuff
2000 F-250 7.3L 315/75/16 BFG Muds Ford 16" Alcoa wheels Tint 4" Straight Pipe 5Ē Tip Volant Edge Juice w/ Attitude Superchips Flashpaq Airaid Poweraid TBS Aftermarket Trans Predator Airfury Zoodad Mod '07 Mirrors & Headlights Alpine in-dash tv unit Cobra CB 19DXIV w/ 3 Firestick Weather Guard TB B&D Tow and Stow Cat Back-up Lights
STC73 is offline
