tymar better than AFE 1? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 06-19-2008, 10:34 PM Thread Starter
young and dumb
theham1105's Avatar
i bought a AFE stage 1 and it was on backorder, so i did the tymar filter diy thing. i just received my AFE and was wondering if i should just return it. my DIY is just the filter clamped to the stock tube.
2002 F250 Lariat 4x4 SRW
Currently:
8.5" procomp lift,
37/13.50/20 Toyo Muds, XD Hoss Bronze Rims
DP 80e 120r 140
JW VB, Racer X TC
DIY intake, 4" straight before RW
Kenwood DNX5120, 2 Kicker CVR10's,
Recon lights all out back
Shocker 540 Train Horn Kit
Custom Wrap by
theham1105 is offline
post #2 of 10 (permalink) Old 06-19-2008, 10:35 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: tymar better than AFE 1?
I would send it back... The Tymar will flow more then the stage 1... You could get the Tymar intake that Airflo sells with a BIG ARSE AFE filter. That filter is huge!
Joe
CSIPSD is offline
post #3 of 10 (permalink) Old 06-19-2008, 10:40 PM Thread Starter
young and dumb
theham1105's Avatar
ok. thats what i figured. ill prob end up making an equivalent to ariflo's. so for now ill stay with the $52.95 intake system i have.
Currently:
8.5" procomp lift,
DP 80e 120r 140
JW VB, Racer X TC
Custom Wrap by
post #4 of 10 (permalink) Old 06-19-2008, 10:42 PM
CSIPSD's Avatar
You can get the filter directly from him as well. If I didnt have the stage 2 I would be running that filter.
Joe
CSIPSD is offline
post #5 of 10 (permalink) Old 06-19-2008, 10:44 PM Thread Starter
young and dumb
theham1105's Avatar
Oh ok cool. ill keep that in mind.
Currently:
8.5" procomp lift,
DP 80e 120r 140
JW VB, Racer X TC
Custom Wrap by
post #6 of 10 (permalink) Old 06-20-2008, 11:47 PM
Sponsor
VanAackenBrosRacing's Avatar
Send a message via AIM to VanAackenBrosRacing
Flow is a good thing! Although those filters let in some dirt, be careful if your in real dusty conditions!
EMPIRE DIESEL PERFORMANCE OF DUBUQUE IA
Procharger kits for 6.0 and 7.3 powerstroke and LBZ/LMM NOW TAKING ORDERS!
Procharger Cummins kit in R&D
Billet Camshafts w/Custom Firing Order for Duramax Smooths dmax harmonics to prevent #2 journal crankshaft failures in high HP builds.
Precision Turbos Custom 2.6, 2.8, 3.0 billet chargers
VanAackenBrosRacing is offline
post #7 of 10 (permalink) Old 06-21-2008, 12:01 AM
for $53 why would you bother spending more My tymar kits have done a very good job of keeping the dirt out -How can a Donaldson filter not filter well?
00 F350- intake,exhaust, pi convertor/ trans
00 F550- dump, intake,exhaust....TN BB exh coated, pi convertor/trans
01 F350- dump, intake,exhaust, BTS v/b, torque conv.
03 F250- CC SB- 5.4 gas
(2)- 06 Dodge 2500 CC 5.9 twins/trans/tunes/fuel
03 dodge drag 10.5 fuel only
jsf350 is offline
post #8 of 10 (permalink) Old 06-21-2008, 01:20 AM
Non Helpful Member
Deerezilla's Avatar
Air flows filter is only a pg5 so it does let some dirt by. I stick with the paper till he get's the pg7 afe filter.
2 fords that make no power
Deerezilla is offline
post #9 of 10 (permalink) Old 06-21-2008, 04:34 AM
Terminator Nation
My truck dynoed 5-6 hp more with a true Tymar over an old style aFe stage I at the 400 hp level. This was with 3 dyno runs on each on the same day, same dyno. Never a speck of dust using the Donaldson elements over 80,000 miles either. I like it
old man dave is offline
post #10 of 10 (permalink) Old 06-21-2008, 10:30 AM
Haul_n_horses2's Avatar
I just pm'ed him about this. He has just ordered the pg7 version but AFE told him they cannot do the inverted cone part of the filter like the pg5 version. Apparently, the material will not support it.
2002 F350 Lariat CC 4x4 4.10 DRW, with "the ultimate towing setup!": Nov 30, 1999 engine with Fluidampr, Melling LPOP, 910 springs and ARP headstuds, DP-Tuner, DI regulated return, AC singles with 80% over EDM nozzles, BTS dual HPOP, H2e, Spearco 6.0 IC and BTS tranny .
Haul_n_horses2 is offline
