single stack - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 33 (permalink) Old 06-19-2008, 10:04 PM Thread Starter
JHill's Avatar
single stack
Scored a 5"x48"chrome stack, 16"x16"x4" 90* elbow, 18"x4" flex pipe for $25.00 all i need is a 4"-5" adapter and some clamps.
my? is, are you supporting it at the 90 up through the bed, the closest hanger is about 2' from where it goes up looks like i could fab a new hanger and use a few exsisting holes in the frame.
E '99 F-350 CC LB, ZF6, IDP -T4i Mount, Comp. Fuel System, , Reg. Return, Comp Valve springs, ARP's, DI P- Rods, Adrenaline HPOP, Isspro's, Detroit Tru Trac
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #2 of 33 (permalink) Old 06-20-2008, 02:04 AM
Subject Matter Expert
PowerstrokeJunkie's Avatar
Re: single stack
Most people secure it using a u-bolt style clamp to the front of the bed, once at the bottom and once near the top of the bed lip. Drill the two holes, and then run the bolt ends through the bed, nuts on the opposite side.
Stock
PowerstrokeJunkie is offline
post #3 of 33 (permalink) Old 06-20-2008, 02:54 AM Thread Starter
JHill's Avatar
Re: single stack
will do -thanks
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #4 of 33 (permalink) Old 06-20-2008, 03:41 AM
Banned
Re: single stack
If I ever did one I would have a piece of 1/4" plate steel cut probably 8 or so inches square with a bolt hole in each corner to bolt it to the bed floor. Then get a piece of pipe where the OD fits the ID of your exhaust pipe. Cut about a 2 inch section of it and weld it to the bottom of the plate in the center. Then cut the appropriate size hole in the center of that (not necessarily in that order). On the top find a piece of pipe that the OD fits the ID of the stack size you want to run. Weld that to the top of the plate so that it surrounds the hole you cut for the smaller pipe feeding the stack.
Then you just slip your flex, over the lower ring and clamp it and slip the stack over the upper ring and clamp it. With the plate bolted to the bed in each corner it's solid. And it takes care of the pipe adapter and mounting all in one. Just choose plate size and bolt pattern so that the bolts all hit on the tops of a couple of the ribs in the bed floor.
Just a thought.
Charles is offline
post #5 of 33 (permalink) Old 06-20-2008, 03:54 AM
Cummins Power
mech2161's Avatar
Re: single stack
Here's how my stacks are supported in the bed.
Kevin
12v CONVERSION IN PROGRESS, Special thanks to:
South Bend Clutch, MOTORSPORTSSUPPLY.COM, Pure Diesel Power & Performance, Carson Stauffer Diesel Service, Weston Shupe, zstroken
mech2161 is offline
post #6 of 33 (permalink) Old 06-20-2008, 04:10 AM Thread Starter
JHill's Avatar
Re: single stack
thanks guys
Charles, i like your idea. ideally i woud like not to have clamps/brackets up on top so it would look clean in the bed. just the stack comming through
I dont plan on running it yearound to much rain here
thanks again for the diffrent ideas
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #7 of 33 (permalink) Old 06-20-2008, 03:29 PM
Re: single stack
My single stack is supported by a hanger in the bed and by the 4"-5" reducer that is wedged in the 5" hole in the bed.
Southpaw is offline
post #8 of 33 (permalink) Old 06-20-2008, 11:13 PM
Laces Out
bigrpowr's Avatar
Re: single stack
08' F250 4x4 w/ 3:55's
bigrpowr is offline
post #9 of 33 (permalink) Old 06-23-2008, 08:37 AM
Re: single stack
^Makes me wish I had taken a cleaner picture...
Southpaw is offline
post #10 of 33 (permalink) Old 06-23-2008, 10:42 AM
The Fireman
big_stroker's Avatar
Re: single stack
Held up with one clamp on the top of the bed
big_stroker is offline
