MBRP 4" install - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 06-19-2008, 03:53 PM Thread Starter
MBRP 4" install
I bought a 4" MBRP turbo back exhaust for my truck the other day. I looked on their website and I am sure it said typical install time is 1-2 hours in your driveway. I called a few places and the shops are telling 3-4 hours and that most systems don't fit very well etc. Can anyone offer some first hand experience in what the real install time should be.
The hardest part to me should be getting the clamp off of the back of the turbo.
fordsbyjay is offline
post #2 of 13 (permalink) Old 06-19-2008, 04:02 PM
DSTRBD's Avatar
Re: MBRP 4" install
Do it yourself. They are trying to rip you off. Im sure most systems people bring in are the cheap ones that dont fit very well though. This is NOT the case with MBRP. They will bolt right in.
DSTRBD is offline
post #3 of 13 (permalink) Old 06-19-2008, 04:08 PM
Laces Out
bigrpowr's Avatar
Re: MBRP 4" install
the mbrp systems are fit VERY well. hangers line up, bends are perfect, do it yourself!!
08' F250 4x4 w/ 3:55's
bigrpowr is offline
post #4 of 13 (permalink) Old 06-19-2008, 04:25 PM Thread Starter
Re: MBRP 4" install
Well that was my original plan but my truck is in Louisiana and I am in New York working and my vacation started yesterday. I am trying to get it installed so when I get home we can leave on our trip. I hate paying other people to work on my truck unless I have to.
post #5 of 13 (permalink) Old 06-19-2008, 04:37 PM
<-- GO BRONCOS
dblamp's Avatar
Re: MBRP 4" install
I had a shop install mine because my friend works there (I didn't have a sawsall to cut the downpipe), and they said it was the easiest install they have ever had with an aftermarket exhaust. Nothing had to be cut and re-welded, everything fit perfectly. His boss was so impressed, that they signed up to be a MBRP distributer.
The hardest part will be cutting the downpipe, so do it yourself..... unless you have a friend at a muffler shop like me.
Anthony
2002 F-350 SRW 4x4 Lariat Crew Cab, Auto, MBRP 4" T409 Turbo back, AFE Stage 2, Isspro gauges (Pyro, Boost, Trans), BTS VB, DP F-5
(No start, Modified Stock, 60T, 80E, 120race)
Democrats are tyrants.
Republicans are cowards.
Jesus Christ is our only hope!
dblamp is offline
post #6 of 13 (permalink) Old 06-19-2008, 05:29 PM
Stimulated
mattgw86's Avatar
Re: MBRP 4" install
The downpipe definitely sucks. The clamp at the turbo isn't bad, but lining up the new downpipe on the turbo can be a pain.
1995 Chevrolet C1500 6.5
1995 Z28 w/ 2.73's
mattgw86 is offline
post #7 of 13 (permalink) Old 06-19-2008, 05:32 PM
Layson's Avatar
Re: MBRP 4" install
I installed my Dad's in a little over an hour. They are real easy to do yourself!!
Layson is offline
post #8 of 13 (permalink) Old 06-19-2008, 06:43 PM
Doakster's Avatar
Lightbulb Re: MBRP 4" install
Wish I could say the same for my MBRP, wasn't really happy with mine especially because I paid the extra for the high grade stainless.
the straight section right out of the down pipe was rubbing on a cross member, I had all I could do to loosen every clamp and get about 1/8 clearance and then tighten every thing back up, messed with the down pipe to get this as well.
Also the most rear hanger by the shock was not bent correctly and the hanger wanted to fall out and still put the rubber hanger mount at an angle, the bend around the shock was to the point where it touched the rear shock ever so slightly, I ended up taking the rear section off and bending the hangers. It still settled so the pipe hits the shock ever so slightly.
Needless to say I messed with this for quite some time, tweaking here and there, tightening and loosening here and there, and I shouldn't have had to do that. And yes I ordered the right one for my truck.
Definitely not the first exhaust install I've done and I wasn't impressed, but I'm a little of a perfectionist, but aren't we all on here.
2003 F-350 4x4 SC 7.3, WOP QSSB Turbo, Isspro Gauges, MBRP 4 inch, AFE Stage II, , DP Tuned Stock, HI, 40t, 60t, 80t, 80e, 120R, 140ex, 6.0 Trans Cooler, 08 Tow Mirrors, 35in Kumho Mts
1993 International 4600 Dump, 7.3 IDI
Doakster is offline
post #9 of 13 (permalink) Old 06-19-2008, 06:50 PM
Sleep well my brothers
yamt03's Avatar
Re: MBRP 4" install
No problems with the install of mine or the wifes.
Early 99 CC DRW AFE, 4" MBRP,Autometer,6.0 trans cooler, ITP, DP Tuner and cupholder upgrade
Former U.S.A. Res. MP & proud of it!
2005 Dodge 4x4 5.9 With some stuff done to it.
"If you voted for Obama in 2008 to prove you're not a racistÖyou'll have to vote for someone else in 2012 to prove you're not an idiot."
yamt03 is offline
post #10 of 13 (permalink) Old 06-19-2008, 06:51 PM
Doakster's Avatar
Re: MBRP 4" install
I guess I'm special.
Doakster is offline
