Intercooler question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 06-18-2008, 09:37 PM Thread Starter
matthewd11's Avatar
Does anyone know the average pressure drop accross a stock SD intercooler? It has aluminum ends if it matters. Probably doesnt since it is the same core. Thanks
matthewd11 is offline
post #2 of 13 (permalink) Old 06-18-2008, 09:56 PM
Banned
Re: Intercooler question
On a stock truck..... none.
Charles is offline
post #3 of 13 (permalink) Old 06-18-2008, 11:35 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
At 45# on the hot side I see 40# on the cold... Thats on a 6.0 stock IC
Joe
CSIPSD is offline
post #4 of 13 (permalink) Old 06-18-2008, 11:37 PM
Sponsor
VanAackenBrosRacing's Avatar
Send a message via AIM to VanAackenBrosRacing
you could proabably stand to use an intercooler at the point your at. Stock one is probably giving you some restriction. Not sure exactly how much.
EMPIRE DIESEL PERFORMANCE OF DUBUQUE IA
Procharger kits for 6.0 and 7.3 powerstroke and LBZ/LMM NOW TAKING ORDERS!
Procharger Cummins kit in R&D
Billet Camshafts w/Custom Firing Order for Duramax Smooths dmax harmonics to prevent #2 journal crankshaft failures in high HP builds.
Precision Turbos Custom 2.6, 2.8, 3.0 billet chargers
VanAackenBrosRacing is offline
post #5 of 13 (permalink) Old 06-19-2008, 12:18 AM Thread Starter
matthewd11's Avatar
I guess i should have specified. On a similar setup as mine.
Joe, thanks for the info, thats what i was looking for.
post #6 of 13 (permalink) Old 06-19-2008, 12:57 AM
Banned
Sorry. It's just that the pressure drop is because of flow restriction. Move more air, more restriction, more drop.
Don't move much air, don't have much drop (if even measurable).
Charles is offline
post #7 of 13 (permalink) Old 06-19-2008, 01:00 AM
So for the most part anytime there is a measurable drop you should upgrade your intercooler?
Andy
I would like to thank F.A.S.T. for helping with the 2008 pulling season.
For all your fire service repair and fabrication needs. Will travel.
IDM Info Updated 11/07/08
mustang_gt_350 is offline
post #8 of 13 (permalink) Old 06-19-2008, 01:13 AM
Banned
In the same sense that anytime there is a measurable increase in EGT you should upgrade your turbocharger.
It's efficiency. You have to decide what is acceptable for you and your wallet.
Charles is offline
post #9 of 13 (permalink) Old 06-19-2008, 01:17 AM
Sounds good, just wanted to confirm what i have been thinking for a while.
Does anyone know what the drop between the 7.3 to the 6.0 is?
Just curious.
Andy
post #10 of 13 (permalink) Old 06-19-2008, 01:36 AM
CSIPSD's Avatar
Just curious.
To be honest, the 6.0 IC was a waste of time... The only thing good is now if I ever upgrade it more I can just drop in a 6.0 Sperco and be done.
Joe
CSIPSD is offline
