BTS Hpop - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 06-17-2008, 04:22 AM Thread Starter
cemeyer's Avatar
BTS Hpop
For those of you that have a bts hpop, how do you adjust the backlash between the two gears? It has a steel eccentric, but how do you get it to spin
Curt
97 350 CC LB 4x4
Injectors, oil, H2E, studs, 910's, idm, etc...
cemeyer is offline
post #2 of 8 (permalink) Old 06-17-2008, 05:03 AM
Drink til she's cute
Thuglike's Avatar
Re: BTS Hpop
Try sending a PM to Dockboy. He would know.
2008 F-250: High Powers / Dual K16 / 60% Nozzles
ELITE
NO LIMIT
SWAMPS
GEARHEAD
INNOVATIVE
Thuglike is offline
post #3 of 8 (permalink) Old 06-17-2008, 05:29 AM
Re: BTS Hpop
I would call Brian at: 870-422-3673
TerminatorEngineering is offline
post #4 of 8 (permalink) Old 06-17-2008, 05:50 AM Thread Starter
cemeyer's Avatar
Re: BTS Hpop
Thanks guys.
cemeyer is offline
post #5 of 8 (permalink) Old 06-17-2008, 06:06 AM
Needs more hours per day
jtharvey's Avatar
Re: BTS Hpop
I wish I could help, but Cale did all the install for me and I have no idea how he turned the eccentric. I remember him checking it though and IIRC the lash is 10 thousandths. I'm curious to see what you find out.
Jeremy
2000 F-350, CCLB, SRW, 4x4, '04 5.9 Common Rail Cummins Conversion
F1 sticks, Evil Twins Dual CP3's, F1 Springs, Helix 2 Cam, ARP headstuds, ED Turbo, Smarty, BTS Trans
Eventually: Compound Turbos
jtharvey is offline
post #6 of 8 (permalink) Old 06-17-2008, 05:50 PM
aklim's Avatar
Re: BTS Hpop
Doesn't the steel eccentric spin in the bore? Mine did
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U front and A Rear.
aklim is offline
post #7 of 8 (permalink) Old 06-18-2008, 02:32 AM
Re: BTS Hpop
The steel eccentric ideally spins in the bore of the aluminum reservoir. It is nearly impossible to spin without removing the eccentric and reinstalling. You might want to index the eccentric prior to removing, then you can reinstall in the correct clocked position. The correct amount of gear backlash is very important. Once you find the correct clocked position you should remove the eccentric and apply a very light coat of sealant and reinstall. Without sealant you may experience a slight leak.
JMS1 is offline
post #8 of 8 (permalink) Old 06-18-2008, 05:41 AM Thread Starter
cemeyer's Avatar
Re: BTS Hpop
Thats exactly why it would not come out. I had to use a puller to get to get it to break free. I believe I'm going to call BTS though, with the eccentric set for the least amount of lash, I can only get it down to .013. I checked the backlash of the bottom pump before I started and it was on the low side of the factory specs, .0055-.006. After getting the eccentric out, it seemed to have a lot of clearance to the housing bore, not really a snug fit.
Curt
97 350 CC LB 4x4
cemeyer is offline
