"New" HPOP, quit and won't start!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 06-16-2008, 03:26 AM Thread Starter
farmb0y's Avatar
Quick background: I just put in new single shot stage 1 injectors from RDS, been tuning with Tony, must have been too much HP and had to be in a new tranny from BWD. Been working with Tony on tuning, and have been getting a little bit of smoke when I think I shouldn't be. With my truck an early '99, and big oil too expensive for me now, I got a used '02 HPOP for $100 from a junk yard.
Got it put in tonight, cranked on it for a little while and it fired and ran. Shut it down, cleaned some stuff up and then fired it back up to take it for a test drive. 1.5 miles down the road it didn't feel like it was running right and then quit on me. Now I can't get it to start again. The HPOP is moving oil, there's fuel in the fuel bowl. Pulled the chip. Nothing is helping it. Any ideas what more to look for? Or is there enough air that it won't start and I just need to keep cranking on it as I've read in other posts?
I want/need to get it running since I'm scheduled and paid to put it on a dyno this weekend at a local dyno days. Any ideas/advice is greatly appreciated!
'08 F350 4x4 CCSB Lariat 6.4L PSD
DPF delete, KEM Tunes, Air bags, hitches and a big fuel tank.
'99 F350 4x4 SCSB Lariat 7.3L PSD (for sale!)
4" exhaust, intake, Casserly Stage 2 injectors, Wildman tunes, updated intake assembly w/van turbo, 17*HPOP, regulated fuel return, BWD tranny
farmb0y is offline
post #2 of 17 (permalink) Old 06-16-2008, 03:29 AM
2nd class citizen
1snotrocket's Avatar
Re: "New" HPOP, quit and won't start!!
cheak the hpop resevior for oil.double check electrical connections.
2003 CRW CAB LB 4X4 6SPD,AFE STAGE 2,38r,DP TUNER,4'' MBRP,FASS 15,Farmers Disel Performance 160/100 injectors,ITPREG.RETURN,TERMINATOR
2001 crw cab short bed auto 4x4 5"exhaust afe stg 2,f6,jw trans,terminator,cass. stg2's,itp reg return,fuel lab pump.
1snotrocket is offline
post #3 of 17 (permalink) Old 06-16-2008, 03:35 AM
When you say, the HPOP is moving oil, how did you check that? Do you have a gauge on the rail or AutoE? Check the IPR plug. Did you remember to flip the buckle to lock the plug in?
TerminatorEngineering is offline
post #4 of 17 (permalink) Old 06-16-2008, 03:41 AM Thread Starter
farmb0y's Avatar
The HPOP resevoir is just shy of touching the plug, assuming that's as full as it gets. I filled it before I tried starting it for the first time. I went through and unplugged and replugged all the connections I took apart.
TE- I disconnected one of the lines going to the head and had the old man crank on it and it would moving oil. Didn't seem like anything that was high PSI, but there was no resistance there either. I will be putting an AE to it tomorrow. I'm new with it, are they able to log info even if the engine is just cranking? We are gonna try putting a gauge in the rail as well. I check the IPR plug. Haven't gone as far as to change the whole IPR back to the old one. We did swap out the coil, thinking maybe the "new" one was bad. That made no difference.
Thanks for the quick responses!! There may be something simple I missed. What's confusing is that we had it running and driving. I'm wondering if either the fuel or oil may be air locked??
farmb0y is offline
post #5 of 17 (permalink) Old 06-16-2008, 03:46 AM
Farmboy, the oil you seen could just be low pressure oil feeding through the system. One more thing you can check: Make sure the HPOP gear bolt is tight. Maybe the gear is slipping.
post #6 of 17 (permalink) Old 06-16-2008, 04:22 AM Thread Starter
farmb0y's Avatar
That crossed my mind, since it is only a friction fit for the gear. I torqued it down to 95 ft-lbs as my Chilton Manual spec'd out. I had to put a socket and breaker bar on the crank to keep from turning the engine over. So I'm hoping it's tight. We'll get a PSI gage on it tomorrow and hopefully that'll clear up a lot of things.
Something else that could be a culprit, CPS. There is a new one in there, but when cranking, the tach seems slow to react and only goes up to maybe 200rpm. Maybe that's all it's cranking at, but wondering if it's not suppose to move at all when they are dead??
Boy, I'm just frustrated after working on it and hoping to have it running for this weekend, heck we even had it running!! It's hard to get to sleep now! Plus, I'm waiting for the wife who is on a business trip to West Palm Beach, FL to call when she get's there. For some reason I'm kinda jealous she's there. ??
farmb0y is offline
post #7 of 17 (permalink) Old 06-16-2008, 04:27 AM
If the gear is fine, I would look at the IPR and the harness to the IPR. Or just wait until you have access to a scan tool.
I forgot to ask: Is the check engine light on?
post #8 of 17 (permalink) Old 06-16-2008, 11:27 AM
JimTJr's Avatar
Since this has not been answered yet,,,
YES, AE will "LOG" and show your ICP pressure among other things, even when just cranking, you should have 4-500 lbs IIRC,,
Joey will get you helped too I am sure....
JimTJr is offline
post #9 of 17 (permalink) Old 06-16-2008, 07:03 PM
Village Idiot
southmike's Avatar
did you loose the little check valve spring thingies on the ends of the oil lines... ?
southmike is offline
post #10 of 17 (permalink) Old 06-16-2008, 07:37 PM
<<<<< Next Generation
boggerr's Avatar
Check make sure you don't have the IPR and the EBPV plugs switched around.
N.E. Terminator Tech
2000 F350 Lariat CC 4x4 LWB Auto
DP-Tuner F5, Terminator HPOP, QSSB, ITP's fuel system, BTS trans.
boggerr is offline
