exaust question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 08-28-2007, 04:46 PM Thread Starter
exaust question
my buddy took his exaust off about 4 inches in front of his rear axle. he said it helps m.p.g. and performance because less backpressure, plus it helps hear the turbo better. my question is could that do damage to anything? could it rust the underside of the truck cause the exaust fumes?
bighunterjpk is offline
post #2 of 20 (permalink) Old 08-28-2007, 04:52 PM
Slated4Greatness's Avatar
Re: exaust question
I doubt it help with MPG but it will add fumes under the bed and cause the underside to be coated with soot. JMHO.
2006 F350 Lariat Tow Boss W/training wheels.
SCT W/GH's tunes, ARP's, Blk & Heads milled, Strictly RR and aux coolant lines, 6" Aussies, Snow MPG-Max, BPD: VK688,EGR, W/Pump, and FICM, Coolant filt, Train Horns, CTS (Monitor only) + Autometer backups
RIP Muley 9-25-09
Keep on Honkin' Jerry 04-05-10
Slated4Greatness is offline
post #3 of 20 (permalink) Old 08-28-2007, 05:33 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: exaust question
Soot... I have a cut out I can open from the cab, its installed by the tranny X member. It covers the underside of the truck! No HP gain on the dyno, no EGT change on the road, just sound!
Joe
CSIPSD is offline
post #4 of 20 (permalink) Old 08-28-2007, 05:37 PM
Re: exaust question
:supergay:
gregrob is offline
post #5 of 20 (permalink) Old 08-28-2007, 09:04 PM
CSIPSD's Avatar
Re: exaust question
Originally Posted by gregrob View Post
:supergay:
YOUR GAY...
Joe
CSIPSD is offline
post #6 of 20 (permalink) Old 08-28-2007, 09:15 PM
Head Thread Derailer
Timbeaux38's Avatar
Re: exaust question
We installed an electronically operated cut out at on Matt Stuckey's old CR a few years ago at Garmons. It was in front of the Muffler, and picked up 5 hp on the dyno, covered the undercarriage and tailgate in soot though.
01 DODGE CUMMINGS EDITION
Originally Posted by bigrpowr View Post
The big boys dont drive powerstrokes.
Originally Posted by Powerstroke Racer
I'm not interested in going out and setting the world on fire(remember this is a Power Stroke
Timbeaux38 is offline
post #7 of 20 (permalink) Old 08-28-2007, 09:48 PM
CSIPSD's Avatar
Re: exaust question
Thats what mine does... the whole underside... I'll get a quick video tonight...
Joe
CSIPSD is offline
post #8 of 20 (permalink) Old 08-28-2007, 10:02 PM
USN-Retired
LarryM's Avatar
Re: exaust question
I might be completely wrong on this, but it thought soot when subjected to moisture over time becomes caustic/acidic and not good. This is why IIRC cracked flue linings in brick chimneys can destroy the brick work over time. You might do some "googling" on soot and moisture and see what you find.
Just something to consider/tink about
I would have loved to do something like that with my Van to solve my "drone" problem but all I could come up with was the following which wasn't exactly what I wanted. Before you ask that was actually installed on a function exhaust system and tested at idle, but not on the highway. However, if you saw that or even "TWINS" driving down the highway you would do a double take ...
Larry
2001PSD(PCM:HPI2)SD E-350,Dk Emerald Grn,4.10LS, BTS
,3.5"/4" exhaust w/Magnaflow/Aeroturbine,203* T-stat/Zerex G-05,AMSOIL air/oil-bypass/rear end 75w-140 fluid,3/8" fuel sys w/10Ķ DAHL100 & fuel manifold/sight glass,6 way dr. seat, Magnefine trans/P.S. filters, husky mats,5 gauge A-pillar ISSPRO EVs w/Grn mkr illum. + air & fuel restriction gauges,coolant filter and zinc electrode, manual GPR switch & GP LED, blinking security LED, weathertechs, a few other "Gadgets"
LarryM is offline
post #9 of 20 (permalink) Old 08-29-2007, 03:07 AM
CSIPSD's Avatar
Re: exaust question
Here is the cut out video...
http://videos.powerstrokenation.com/...98017751a3.htm
Joe
CSIPSD is offline
post #10 of 20 (permalink) Old 08-29-2007, 02:11 PM
Re: exaust question
cannot get the vid
NWSUPRD is offline
