tru-trac - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 31 (permalink) Old 08-27-2007, 09:13 PM Thread Starter
Just A Squirrel
dstruble's Avatar
tru-trac
http://www.ringpinion.com/ProductDet...spx?ProdID=221
Is this the right LS for me?? Dont really like the manners of lockers but I'm tired of the 1-leggers!!!
Darrin Struble
2003 F-350XLT Sport SC/SB
7.3L Live tuned by Jody ,ITP reg return/intank prepump mods, MBRP S.S. 4" ,afe stage1,foil delete,WW, Dieselsite coolant/trans filters,turbomaster wastegate controller,FTVB,Bandwagon Badges
1956 f100 Heidts Suspension all around
dstruble is offline
post #2 of 31 (permalink) Old 08-28-2007, 12:09 AM
Laces Out
bigrpowr's Avatar
Re: tru-trac
i love mine!!!
08' F250 4x4 w/ 3:55's
bigrpowr is offline
post #3 of 31 (permalink) Old 08-28-2007, 12:19 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: tru-trac
So how hard is the install... Is this a drop in deal or do I have to set the backlash again... I am very tired of the one wheel peal...
Joe
CSIPSD is offline
post #4 of 31 (permalink) Old 08-28-2007, 01:02 AM
Re: tru-trac
I had mine installed by a guru and the backlash didn't need to be adjusted. If you are looking for a LSD, it seems to be a great unit.
2002 f-350 PSD, 4x4, cc short bed, 6spd, ccv mod, airdog, AIS filter, isspro ev and scangauges, detroit TT, ITP boost annihalator, ITP RR, bellowed up-pipes, ats housing, turbomaster, 3.5 dp magnaflow, very happy with ultra smooth and linear PHP 50t, 80DD and "whisper" tunes.
clydesdale is offline
post #5 of 31 (permalink) Old 08-28-2007, 02:50 AM
War Pig
Caballo Diablo's Avatar
Re: tru-trac
i personally like the ARB lockers. but i guess it all depends on what you use the truck for. but it was nice to be able to flip a switch and have a full locker when needed
Chad
04 F350, CC, LB, 4X4 Fat Bottom Girl....Butt A$$ Stock
SOLD>>>'00 F250, DP-Tuner, 5" Straight Pipe, S&B intake, autometer, Racer X TC and VB, Full Force Stage 1, prepump/in-tank mod, Annihilator, 203*
ET: 5.024 250' Mud Track
Caballo Diablo is offline
post #6 of 31 (permalink) Old 08-28-2007, 03:32 AM
DSALF250's Avatar
Re: tru-trac
Will this unit give you a two wheel peel? I used to do two wheel peels but now down to one....L/S gone?
99 F-250-SOLD
2006 Dodge Ram Big Horn Edition Quad Cab 4x4 SB, Smarty/Edge EZ, FBD 5" exhaust system HTT turbo...... and an Airdog 150 compliments of Charlie & Competition Diesel....more on the way.
502/960
DSALF250 is offline
post #7 of 31 (permalink) Old 08-28-2007, 05:26 PM
Laces Out
bigrpowr's Avatar
Re: tru-trac
its a locker. just not full time. as soon as your on the throttle its fully locked. as for install, it was pretty basic. pressing the bearings and removing them were the only pita. no backlash issue or shims needed on mine.
bigrpowr is offline
post #8 of 31 (permalink) Old 08-28-2007, 05:33 PM
Re: tru-trac
You needed a locker?
I didn't know you could spin your tires
gregrob is offline
post #9 of 31 (permalink) Old 08-28-2007, 05:39 PM
Laces Out
bigrpowr's Avatar
Re: tru-trac
come on now....one day i might be able to. but at about 40 mph i can.
bigrpowr is offline
post #10 of 31 (permalink) Old 08-28-2007, 05:42 PM
Bill
badford350's Avatar
Re: tru-trac
I had one in the front of a full size bronco. It worked great. When you let off the throttle it would allow you to turn without the tires binding up. But once you got on it again away you would go. I donít know about that one in daily driver in the rear though. I would think an arb would be better in that case. Driving with lockers on pavement are a pain in the butt and hard on tires. Not that burn outs are though lol
02 f350 larit, itp rr & pre pump filter, GTP38r, international up pipes, swamps 175/146 single shot's, DP tuner, factory tech valve body & lot of extra lights
badford350 is offline
