Auto Trans options besides total rebuild - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 08-27-2007, 05:41 PM Thread Starter
Got 'Er Did
lownslow's Avatar
i have a friend that recently aquired a 2000 F350 Crew Long Auto with 113K miles
right now it is bone stock with the expection of a 4 inch TB Exhaust and Gauges
he is most likely goin to get a DP Tuner
but he was wondering what to do with the trans? he cant dump $4k into a built trans so what is a good road to go down?
We have a ATS Dealer 4 hours away so it would be nice to stay with them if they are quality
so which direction should i piont him?
convertor?
control box?
whats the co pilot option?
what about a upgraded valve body? what do they do?
2009 Mustang GT Premium 5spd
BBK Long Tube Headlers and Off Road X Pipe
waiting for the squeeze
1995 F350 Crew Long 4x4 Dually
Powerstroke
Auto
4 inch MBRP
lownslow is offline
post #2 of 11 (permalink) Old 08-27-2007, 05:59 PM
AllYourBaseAreBelongToUs
imelmo's Avatar
Re: Auto Trans options besides total rebuild
A good aftermarket converter and a valve/spring kit or valve body and you should be good to go. I ran that set-up on my truck for a while with mini-me injectors and a 38r. It wasn't 'til I started using the nitrous that I needed the full built trans.
EMPIRE DIESEL, PERFORMANCE TRUCK PRODUCTS, CEN-TEX DIESEL PERFORMANCE, AND DIESEL INNOVATIONS
ALSO LOTS OF HELP FROM (IN NO PARTICULAR ORDER) TWISTED DIESEL PERFORMANCE, FCDP, ITP, MATT WITH GEARHEAD, ERIC WITH INNOVATIVE, DOUG WITH GOGO DIESEL, CASS WITH FULL FORCE DIESEL, AND SWAMP'S
2005 F350 Fat-Butt Truck
2004 ECSB Procharged F250
imelmo is offline
post #3 of 11 (permalink) Old 08-27-2007, 06:01 PM
Banning Smut
PTSUPERD's Avatar
I have been running a Suncoast convertor and Transgo kit for around 3 yrs. that is with a full fuel system, hybrids, and a Garrett BB turbo.
PTSUPERD is offline
post #4 of 11 (permalink) Old 08-27-2007, 06:15 PM Thread Starter
Got 'Er Did
lownslow's Avatar
so a good convertor and valve body upgrades will go a long ways then?
is there anything that will help with the free wheeling factor of an automatic besides an exhaust brake?
Powerstroke
Auto
4 inch MBRP
lownslow is offline
post #5 of 11 (permalink) Old 08-27-2007, 06:24 PM
You can have Jody program the chip to keep the converter locked which will help slow the truck. You can also lock-out O/D on decel which will also help slow the truck. Those are about the only things you can do other than turn your EBPV into a brake or buy a real ex brake.
69W900A is offline
post #6 of 11 (permalink) Old 08-27-2007, 06:33 PM
imelmo's Avatar
Or you can do the torque converter maual lock-up mod. Real easy to do and only aobut $10 in parts.
http://www.dieselinnovations.com/techfiles/tclockup.pdf
imelmo is offline
post #7 of 11 (permalink) Old 08-28-2007, 07:31 AM
You can also have Jody program to keep the converter locked on downshifts to hold you back
It's sooo coooool!!!! Just like an alison
gregrob is offline
post #8 of 11 (permalink) Old 08-28-2007, 08:24 AM
Terminator Nation
TransGo TuggerII reprogramming/valve body kit. This also has a optional mod that requires dropping the trans to drill out a passage for higher fluid flow. But if you're replacing the t/c no big deal. Try bulkpart.com or bulkparts.com, you can buy it online from them. last time I checked their website, the kit was about $120.
old man dave is offline
post #9 of 11 (permalink) Old 08-28-2007, 04:23 PM
Braaaaaaaaaaaap
Dysfunctional's Avatar
2nd the tugger kit... it will keep you from burning up the low/reverse clutch during compression braking in 1st and 2nd.
It reworks the vb's...
-but you have to pull the pump (need a slide hammer to do that)
-some mod's to the pump (I added a on/off lockup valve for the TC while I had it apart)
-upgraded coast clutch snapring
-upgraded overdrive clutch snap ring (I managed to get the spiral snap ring on the overdrive clutch with some serious patience a couple screw drivers and a bit of swearing) Otherwise, you need a special tool to compress the spring to do it.
'00 F350 CC LB 4wd 7.3L with stuff, haulin' a 40' trailer with toys
Dysfunctional is offline
post #10 of 11 (permalink) Old 08-28-2007, 05:23 PM
Hated by All
Fast_Ashley's Avatar
ATS sucks....... Try a BTS v/b and converter or a JW v/b and converter
PARIAH
2001 F-350
Resurection has begun.....
Fast_Ashley is offline
