No waste-gate...??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 05-06-2011, 07:05 PM Thread Starter
Matt
No waste-gate...???
I heard If I take my stock turbo waste gate off I can see higher boost levels?!? If so and not that bad I would like to do it on the dyno next weekend?!? Any thoughts??? Thanks
Matt... 00' F250, Wicked wheel turbo, 6.0 IC, Beans stage 1 injectors, modified IDM, TS 6 custom tune chip by Jonathan at bdp, s&b stage 2 intake, ATS tc with heavy duty rhino tranny, BD valve body, 5in exhaust with 7in black stack
00'nasty7.3 is offline
post #2 of 6 (permalink) Old 05-06-2011, 07:09 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: No waste-gate...???
You can unplug it if you like, easy enough. Doubt you will see much if any more HP on the dyno.
Boost does not equal hp.
Joe
CSIPSD is offline
post #3 of 6 (permalink) Old 05-06-2011, 07:11 PM Thread Starter
Matt
Ok thanks
post #4 of 6 (permalink) Old 05-07-2011, 12:45 AM
Ticking time bomb
Leave it plugged in.
I wonder what my sig and avatar will get changed to now!!
groomzybanshe is offline
post #5 of 6 (permalink) Old 05-07-2011, 06:39 AM
TARM's Avatar
What boost numbers are you hitting with it on? If its 27 or more you will gain nothing and could actually lose IMO.
TARM is offline
post #6 of 6 (permalink) Old 05-07-2011, 03:46 PM Thread Starter
Matt
When I punch it will climb up and I hit 29 and it stays there from 65 on up to 100... I think I will just leave it plugged in, it's a long drive to the event and I need to drive it home lol but I will be doing the dyno and burn-out contest... So if something happens... It's ok I have a motor in the shop
