A fuel system lesson - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 08-22-2007, 05:04 AM Thread Starter
The following is part of a PM I sent a fellow user. It took me a long time, actually getting my hands dirty (god forbid), and talking with Dennis at ITP to figure out the stock system and how it all works.
I know some of you were born with this knowledge and may scoff at my elementary understanding of a stock PSD fuel system, but never the less, I needed to be educated.
I'm putting this out there so hopefully others who may not know will gain a better understanding of how the fuel system works and what ares of it need to be addressed.
I'll explain how the routing of the fuel goes from tank to bowl to heads to regulator/bowl, to return line back to tank, and the purpose/need for modifications to the fuel system.
1) Line comes from pickup in tank and runs to fuel pump
2) line leaves fuel pump and is fed into the bottom, DRIVER'S side of the fuel bowl You will see a hard line for this.
3) Fuel leaves the fuel bowl via 2 ports on the bottom passenger side of the fuel bowl. You will see 2 hard lines for his.
4) Fuel leaving those hard lines is fed to the FRONT of driver's side head and the REAR of the pass side head.
5) The Fuel then dead heads in the heads and there are check valves in each head at the feed locations. These check valves are thought to be there to minimize the affect of the harmonics created by the injectors firing asynchronously.
6) The fuel is regulated by the internal regulator in the bowl, whatever fuel is not needed is forced by the regulator and makes its way down the return line on the TOP-DRIVER'S SIDE of the fuel bowl
7) The return line from the regulator runs all the way back to the tank and is dumped in to a mixing valve, where it is mixed with new fuel coming from the tank. This preheats the fuel.
8) Areas that need addressed to eliminate (or at least drastically reduce) air intrusion, and fuel aeration are
>> a) Remove mixing valve in the tank, big source of aeration.
>> b)Remove quick disconnect fitting on the pickup going to pump. These quick disconnects seal fine under pressure, but under suction they leak air.
**Above A,B is commonly referred to as the "Hutch Mods" or also called "In Tank" or "Pre-Pump" mods.
Aside: you will also need to install some sort of pre pump filtration / water seperation as the mixing valve has 2 small filters which trap any particles that may make their way to the fuel pump and damage it.
>> c) Remove the "Dead Head" stock fuel system design by creating a flow through system which is externally regulated. This is accomplished by feeding the end of one head (doesn't matter which end) and allowing fuel to travel through the head and out the other side by means of connecting a return line from the head to an external regulator.
9) Deleting the stock fuel bowl is merely preference as it allows better access to the top of the engine, gives the engine bay a much cleaner, open look, and creates a wider choice of cheaper/better/more available fuel filter elements as opposed to the stock one.
The ideal setup IMO will use a 10-100 non-restrictive filtration system pre pump and a finer, more efficient filtration system, such as a 2 micron element, post pump.
A heated pre pump element with good water seperating capabilities is also recommended, especially for those in colder climates.
While you have access to the tank during the pre pump stage of fuel system modifications, you can cut off the vent tube that runs along the factory filler nozzle to allow the tank to fill almost completely without activating the pressure-sensitive nozzle shutoff on diesel pumps. This is commonly called the "harpoon mod". Makes filling the tank completely a breeze.
gregrob is offline
post #2 of 21 (permalink) Old 08-22-2007, 05:08 AM
Hated by All
Fast_Ashley's Avatar
Re: A fuel system lesson
Now if you would just pony up and buy Dennis' kit instead of dicking around.....
PARIAH
2001 F-350
Resurection has begun.....
Fast_Ashley is offline
post #3 of 21 (permalink) Old 08-22-2007, 05:13 AM Thread Starter
I might add that Dennis at ITP diesel has all the parts needed to do every stage of the fuel system work you may tackle, including a high performance fuel delivery system.
In tank / Pre Pump kit
http://www.itpdiesel.com/store.php?c...on=show_detail
I've purchased and installed this kit and it's very nice, instructions are written well, good quality materials used and everything fit perfectly.
Regulated return fuel system
Bowl delete kit
Dennis has been more than helpful answering my fuel system questions and is very knowledgable. Thanks Dennis!
gregrob is offline
post #4 of 21 (permalink) Old 08-22-2007, 05:14 AM Thread Starter
I eventually will when funds permit
gregrob is offline
post #5 of 21 (permalink) Old 08-22-2007, 05:16 AM
Hated by All
I just got mine last week, and my bowl delete showed up this afternoon.
I'll trade ya' for the Terminator
PARIAH
2001 F-350
post #6 of 21 (permalink) Old 08-22-2007, 05:20 AM Thread Starter
NO
gregrob is offline
post #7 of 21 (permalink) Old 08-22-2007, 05:26 AM
Hated by All
Originally Posted by gregrob View Post
NO
I'll trade ya' a common rail for it
PARIAH
2001 F-350
post #8 of 21 (permalink) Old 08-23-2007, 02:10 AM
Corona Killa
THEDIESELMAN's Avatar
I'll buy you a Terminator for a common rail
2007 DODGE 2500 CREW CAB 4X4 5.9 LITER CUMMINS
2002 FORD F-250 CREW CAB 4X4 POWERSTROKE
THEDIESELMAN is offline
post #9 of 21 (permalink) Old 08-23-2007, 02:35 AM
RDRCM
CooterBrown's Avatar
A true lesson would have involved the name Hutch and been less of an ITP commercial IMO
#49
Sold
2006 Almighty CumminGs
CooterBrown is offline
post #10 of 21 (permalink) Old 08-23-2007, 07:58 AM Thread Starter
I added the term Hutch mod.
Dennis has helped me a ton with my fuel system stuff even though I've bought very little from him. He's a good guy and very knowledgable and I'm going to give him credit when I can.
gregrob is offline
