Stock ride height - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 11-26-2019, 02:57 AM Thread Starter
Stock ride height
Yes I know it's been asked but I cant find it i swear a suck at searching stuff I'm also new to the page.
Can someone with a 02 f350 that's stock measure from the center of the hub to the bottom of the fender or from center of the shock bolt hole to center of shock bolt hole for me. I bought my truck used and I'm trying to figure out what size lift is on it. Guy I bought it from said its lifted and theres 5 leafs up front and not just 2 so its definatly got something going on.
A measurement with a lift will also do if your positive with what lift you have
Sam350 is offline
post #2 of 8 (permalink) Old 11-26-2019, 05:15 AM
HilhavenFarm's Avatar
Re: Stock ride height
Just measured my friends truck.
2001 F250 4X4, the stock front height was exactly 24" from hub center to fender well. Measurements for the rear was 21" stock.
Hopefully some one else will chime in to verify or give comparison.
1996 F350 XL Crew Cab LB 4x4 3:55
Former Ft. Bragg/Pope AFB Truck
DieselSite Coolant Filter
Riff Raff Diesel Turbo & Y Boot Kit
Riff Raff Diesel HPX
Mile Marker 449SS Manual Hubs
1987 F250 XLT Lariat LB 2WD 4:10
6.9/7.3 IDI Swap-SOLD
2010 John Deere 5055D
1974 Deutz 5506
2950 hours-"The Tank"
HilhavenFarm is offline
post #3 of 8 (permalink) Old 11-26-2019, 09:56 AM
alleged moderator
tjctransport's Avatar
"stock" can vary depending on whether it has soft ride springs on it, or a "X" code plow package springs.
i have seen factory stock trucks vary in height by as much as three inches
tom
tjctransport is offline
post #4 of 8 (permalink) Old 11-26-2019, 10:33 AM
PSN intsigator
heavydoc's Avatar
My 02 sat very low in the front, almost looked like a 2wd. Put the procomp 22210 springs in it and it leveled almost perfectly
96 F350 rclb drw 2wd psd (built not bought)
01 Excursion Limited 4wd psd (the wifes ride)
02 F350 cclb drw 4wd psd (the land yacht)
heavydoc is online now
post #5 of 8 (permalink) Old 11-26-2019, 01:51 PM
don't play well w others
Dustybumpers's Avatar
Like the window licker said....
My 03f 350 sat 3" higher than my 02 f 350, so just depends on the factory set up. my 03 had 3 spring leaves in front, the 02 has 2
Originally Posted by Mr_Andy View Post
Not gonna lie, when I first saw this thread title I had visions it was going to entail a Filipino whore named Destiny and an itch that wouldn't go away.
Charlie
"A common mistake people make when trying to design something completely fool proof, is to underestimate the ingenuity of a complete fool."
Dustybumpers is offline
post #6 of 8 (permalink) Old Yesterday, 02:10 PM
Let'er Buck!
Strokersace's Avatar
Then someone prior to you put an add-a-leaf on the front of the 03. All front springs, no matter the rating, were a 2 leaf setup from factory.
In the front the only thing that changed the height is the spring rating. In the rear, it was spring rating AND the size of the factory lift block. F250 and f350 dually has a 1 7/8 block and the F350 srw had a 3 7/8.
Im sure some f250s may have been custom ordered with the taller block but not sure. Everyone Ive been around was the shorter one.
I got truck stuff...
Strokersace is offline
post #7 of 8 (permalink) Old Yesterday, 02:55 PM
Truck was ordered, and received straight from Ford. When I picked it up it has 3 miles on the odometer. I was the original owner.
Charlie
post #8 of 8 (permalink) Old Today, 12:07 AM
Let'er Buck!
I stand corrected. In all of the OBS or a super duty trucks that I have worked on and on over the years, I have never seen one come with an add a leaf in the front from the factory.
