2001 F-250 7.3 Intermittent Miss - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 11-12-2019, 05:11 PM Thread Starter
bholt's Avatar
Ok I have the 2001 F-250 4X4 Super Duty Off Road with the 7.3 Diesel, with 240,000 miles. It has been a great truck and I am the original owner. About a year ago I had an issue where after starting and after about lets say 5 minutes the truck would just die. I could put it in neutral or park and restart, then be fine. Most of the time it would happen when idling or slowing down at alight. after doing some research I installed a new cps (Camshaft) sensor and a ICP sensor witch was stiil OEM, That solved the problem it has never recurred.The bad part is I replaced both at the same time and really don't know which one was the culprit.I'm thinking it was the ICP since I had replaced CPS sensor before. It would not start at all until I replaced it, and then it was good.
I give all this info because my current problem is that it seems to be running a little rough and when I reach 65+ MPH ever so often it will miss out like once then again but after that be OK. I had a Mechanic ride with me with his tablet connected, all injectors were good/strong as was everything else. I had him replace the wiring loom under the valve cover thinking a wire might be broke but it did not correct the issue. I have reviewed several You tubes and they all seem to focus on the ICP sensor. since I bought the replacement at advance for about eighty dollars and read somewhere that someone said "don't go cheap", i'm thinking maybe I did. I have not pulled the connection looking for oil or anything else.
I am frustrated and thinking about going to a dealer but know that is really gonna hurt. Does anyone have any idea as tho what could be causing this?
bholt is offline
post #2 of 5 (permalink) Old 11-12-2019, 07:01 PM
If you have the ability to look at ipr load and ICP voltage I would recommend doing that and logging your numbers first. Also pull the plug on the ICP with truck shut off to check for oil. Do you get a CEL when it runs rough at those speeds? Does it sometimes do it at idle? If it does it at idle, I would pull the ICP with engine running to see if it wants to stall out and then quickly come out of it.
Derpin is offline
post #3 of 5 (permalink) Old 11-13-2019, 11:47 AM Thread Starter
bholt's Avatar
Re: 2001 F-250 7.3 Intermittent Miss
Do not get any check engine lights and while it seems a little rough no bad and after it misses a time or two at highway speeds, seems that once it's its out of it's system thats it.
bholt is offline
post #4 of 5 (permalink) Old 11-14-2019, 12:27 PM
How about fuel and filters? How many miles on the oil change? If you shut over drive off will it still do it? I am assuming that in OD is when it is starting to act up at highway speeds.
01 F450 7.3 Utility Body
180cc 30% injectors
38R turbo
TS Chip
K and N intake
6" stacks
Lifted 04 6.0
Intake/exhaust
Stock motor
DieselJB is offline
post #5 of 5 (permalink) Old 11-16-2019, 01:50 PM Thread Starter
bholt's Avatar
Change fuel filters regularly oil every 4000 mi with shell rotella. about 900 mi. ago.
bholt is offline
