So let’s see if I can get some insight.
02 Excursion Limited 7.3 4x4
Question #1
Power door locks only work on lock, ohms are good through the entire door harness and you can hear the VSM (Vehicle Security Module) clicking during lock operation, replaced main switch just thinking it might be the issue but no dice. Drivers door open and key in the ignition and on, the doors lock and then the drivers door unlocks. Any input????
Question #2
Overhead lie-o-meter wasn’t working, pulled apart and found loose diodes, pushed them back in place and it lite up and the display works but now it has a fuel gauge issue, coincidence or not???
Question #3
Back hatch glass is leaking water, easy self repair or take it to a glass shop?
Question #1
Question #2
Question #3
