Power steering hydra vac issues 2000 f250 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 10-08-2019, 09:52 PM Thread Starter
Rlstiles74's Avatar
I had issues turning left and stopping so I changed my power steering pump and reservoir, and the hydra vac. I bled the system by turning wheel lock to lock (Wheels up not running) That fixed the problem for about 2 weeks now It’s tightb turning to the right. I’ve tried bleeding the system again turning lock to lock (not running) about 60 times each way. Any suggestions would be appreciated.
Rlstiles74 is offline
post #2 of 8 (permalink) Old 10-09-2019, 01:04 AM
Project Shamu
Lt.Dan's Avatar
Re: Power steering hydra vac issues 2000 f250
Sounds like the steering box, not a pump. How about with the wheels off the ground? Still stiff?
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 378,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
Lt.Dan is offline
post #3 of 8 (permalink) Old 10-09-2019, 02:50 PM Thread Starter
Rlstiles74's Avatar
Turns fine with the wheels off the ground
post #4 of 8 (permalink) Old 10-10-2019, 12:27 AM
Project Shamu
Lt.Dan's Avatar
Does it have plenty of stopping power?
Lt.Dan is offline
post #5 of 8 (permalink) Old 10-12-2019, 03:37 PM Thread Starter
Rlstiles74's Avatar
Yeah. Stops good. Going to try lines, and if that don’t fix it, bout only thing left is gear box
post #6 of 8 (permalink) Old 10-12-2019, 03:52 PM
Project Shamu
Lt.Dan's Avatar
It's not uncommon that people get a bad power steering pump out of the box. Sometimes multiple times.
Lt.Dan is offline
post #7 of 8 (permalink) Old 10-12-2019, 04:01 PM Thread Starter
Rlstiles74's Avatar
Maybe I’ll change it and the lines both and see what happens. Thanks for the advice
post #8 of 8 (permalink) Old 10-12-2019, 08:03 PM Thread Starter
Rlstiles74's Avatar
Well changed the pump and reservoir again, plus the high pressure lines. No change. Now the only thing left is the steering box. Best guess, do ya think it could be causing it?
