White smoke - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 09-21-2019, 01:23 AM Thread Starter
Fibylion's Avatar
White smoke
Okay this truck has always smoked pretty good on start up, 03 7.3 350000 kms, it's got all new glow plugs in it, tuner, new injectors, tested glow plug relay and seems to work, it's really not that cold out and puffs smoke for a good while. Motor just warn out or is there something else I should look at? Doesn't seem to have performance issues since I changed injectors. When I take off fill cap and run it, there seems to be little too no blow by, next to no play in turbo shaft as well. Ideas before winter hits lol?
Fibylion is offline
post #2 of 2 (permalink) Old 09-21-2019, 02:00 AM
PSN intsigator
heavydoc's Avatar
Re: White smoke
Have you tested the glow plug relay circuits, and the wires to the glow plugs
Sent from my SM-N920V using Tapatalk
96 F350 rclb drw 2wd psd (built not bought)
01 Excursion Limited 4wd psd (the wifes ride)
02 F350 cclb drw 4wd psd (the land yacht)
heavydoc is offline
