1999 F350 Super Duty Wheel Removal - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
post #1 of 12 (permalink) Old 09-11-2019, 10:56 PM Thread Starter
Garage
Aluminum wheel removal, The wheels have bonded by electrolysis Aluminum against steel hub. Does anyone have any suggestions on how to remove them? I wish the previous owner had used some Anti-Seize between the two. Any help would be appreciated. Thank You.
EricSStroker is offline
post #2 of 12 (permalink) Old 09-11-2019, 10:57 PM
Kyle_KleinSS's Avatar
Re: 1999 F350 Super Duty Wheel Removal
Take all the lug nuts off and try kicking the tire in different spots.
Sent from my SM-G955U using Tapatalk
Early 99 F350 7.3 PSD Diy Intake,4 in TB straight pipe, 17* HPOP CCV Mod, Foil Delete, HPX, BTS VB, Coolant Filter, Autometer, TW Chip, TC Lockup, EBPV Brake, Tru Cool 4739 sittin on 315/75/R16 Toyo Open County M/T
03 Cobra
97 Saturn SL1
Kyle_KleinSS is offline
post #3 of 12 (permalink) Old 09-11-2019, 11:02 PM
Moderator
Sbluke55's Avatar
Loosen but donít remove the lugs. Then slowly drive in figure 8ís. This is the last thing I would try though. ^^^^^ that comment would be my first attempt
01 f-250, Standard
Sbluke55 is offline
post #4 of 12 (permalink) Old 09-11-2019, 11:09 PM Thread Starter
Garage
Guess I could give that a try Thanks
post #5 of 12 (permalink) Old 09-11-2019, 11:10 PM Thread Starter
Garage
did that one but thanks for responding.
post #6 of 12 (permalink) Old 09-11-2019, 11:10 PM
don't play well w others
Dustybumpers's Avatar
Take the lug nuts loose, not off like stated, let the truck Down off the jack, rock the truck back and forth by pushing from the side. It will clunk when the wheel comes loose
Charlie
"A common mistake people make when trying to design something completely fool proof, is to underestimate the ingenuity of a complete fool."
Dustybumpers is offline
post #7 of 12 (permalink) Old 09-11-2019, 11:20 PM Thread Starter
Garage
Thanks, I will try this also, is it a good idea to soak the mating surface area with penetrating oil also beforehand?
post #8 of 12 (permalink) Old 09-11-2019, 11:24 PM
Moderator
Sbluke55's Avatar
It wouldn't hurt
Dustybumpers likes this.
01 f-250, Standard
Sbluke55 is offline
post #9 of 12 (permalink) Old 09-11-2019, 11:30 PM
This is my favorite for soaking things to break loose
Charlie
post #10 of 12 (permalink) Old 09-12-2019, 08:56 AM
alleged moderator
tjctransport's Avatar
when i had to remove the wheels on the 550 the first time it took driving round the yard with the lug nuts loose to break them loose. when it was put back together everything got a coat of never-seize. no problems after that.
EricSStroker likes this.
tom
tjctransport is offline
