Stomp brakes got brakes. Ease on brakes pedal goes to floor - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 07-11-2019, 11:37 PM Thread Starter
2001 f350. Replaced hydroboost and master cylinder 6 months ago or so and now I’m having an issue with the brakes working fine if I stomp them but if I ease on the pedal I can push the pedal all the way to the floor. On one stomp at about 15-20 mph the brakes locked until I tapped the pedal and then they released.
Momentum wins over traction every time.
Mwsfarms is offline
post #2 of 6 (permalink) Old Yesterday, 02:06 AM
Project Shamu
Lt.Dan's Avatar
Re: Stomp brakes got brakes. Ease on brakes pedal goes to floor
Sounds like air in the lines, have you tried to bleed them?
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 378,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
1983 F150 SCSB Flareside, 302 w/ AOD Trans
2002 F450 SCFB, 7.3 PSD 2wd w/ 144,000 miles
SOLD
Lt.Dan is online now
post #3 of 6 (permalink) Old Yesterday, 04:47 PM
Moderator
Sbluke55's Avatar
I say it's a bad master. But I had an issue like that and it was a caliper.
01 f-250, Standard
Sbluke55 is offline
post #4 of 6 (permalink) Old Yesterday, 11:50 PM
don't play well w others
Dustybumpers's Avatar
Can you feel the ABS pump hit you on the pedal when you panic stop it?
Is the ABS light on?
Charlie
"A common mistake people make when trying to design something completely fool proof, is to underestimate the ingenuity of a complete fool."
Dustybumpers is offline
post #5 of 6 (permalink) Old Today, 12:19 AM
matthewd11's Avatar
I have replaced many abs modulators for this exact symptom of sinking pedal on easy stops but works fine on hard stops.
Make sure you have no sticking caliper slide pins first
matthewd11 is offline
post #6 of 6 (permalink) Old Today, 12:40 AM Thread Starter
Update. Appears to be a bad master cylinder. I changed the master when I changed the hydroboost months back but I guess it gave it up. Put a new master on and after a bench bleed and some pedal pumping I had good brakes back. Only put 10ish miles on it but so far so good. Thank you for the input
Mwsfarms is offline
