New Ford ICP - Running with bad miss and no power - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 07-11-2019, 03:29 PM Thread Starter
'02 F250 Crew Cab SB 200k
Adams260z's Avatar
New ICP and running worse than ever, but no codes. EGTs are high and loss of power. The old ICP was filled with oil and started to throw codes, ordered a Ford one for ~$135. Installed and now it runs okay for the first 2-3 mins then totally falls on its face. Will stay running, but not like it should.
Buzz tested all injectors firing
Fuel pressure stays around 60 psi even under load
Checked the IDM to injector pins and everything checks out
I have not checked the compression on any of the cylinders. Is there a good way to check the ICP? Have to wonder if I got a bad one since it started right when I put the new one in. The #1 cylinder does have a decent exhaust leak that I need to fix, would that do it?
Once again, putting it out there and seeing what help I can get.
'02 F250 Crew Cab SB 200k, Garrett Turbo, 6 pos chip, exhaust
'14 Jeep GC SRT
'79 Yamaha XS1100
'74 Datsun 260z with a 318 SB
'73 Roadrunner with 383 (still a long way to go)
Adams260z is offline
post #2 of 8 (permalink) Old 07-11-2019, 07:25 PM
2000f250's Avatar
You need to get a scanner to see What percentage the ipr duty cycle doing and what pressure the icp is showing at idle. Is the ipr tin nut loose. Did the icp connector fill with oil and damage the wiring there. A exhaust leak will cause some power loss do to no drive pressure on the turbo.
2000f250 is offline
post #3 of 8 (permalink) Old 07-11-2019, 09:28 PM
Project Shamu
Lt.Dan's Avatar
Re: New Ford ICP - Running with bad miss and no power
Unplug the icp and see if it runs okay. It will tell you if the icp is at fault
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 378,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
1983 F150 SCSB Flareside, 302 w/ AOD Trans
2002 F450 SCFB, 7.3 PSD 2wd w/ 144,000 miles
SOLD
Lt.Dan is offline
post #4 of 8 (permalink) Old 07-13-2019, 12:55 AM Thread Starter
Adams260z's Avatar
This is what I have with KOEO. I'm trying the ICP unplugged now to see how it is, but last time it wouldn't even run.
File Type: jpg Screenshot_20190712-204713_1562979335362.jpg (11.2 KB, 3 views)
'14 Jeep GC SRT
'79 Yamaha XS1100
post #5 of 8 (permalink) Old 07-13-2019, 01:02 AM Thread Starter
Adams260z's Avatar
Here is what it looks like running at idle ~750 RPM. I have to look, but aren't those values out of whack? IPR is too high, right?
File Type: jpg Screenshot_20190712-205854_1562979762604.jpg (11.5 KB, 5 views)
'14 Jeep GC SRT
'79 Yamaha XS1100
post #6 of 8 (permalink) Old 07-13-2019, 01:10 AM Thread Starter
Adams260z's Avatar
Here it is with the ICP disconnected at an idle. Can see the difference in the psi. Aren't both plugged and unplugged values pretty high?
File Type: jpg Screenshot_20190712-210744_1562980195134.jpg (9.9 KB, 5 views)
'14 Jeep GC SRT
'79 Yamaha XS1100
post #7 of 8 (permalink) Old 07-13-2019, 03:02 AM
Project Shamu
Lt.Dan's Avatar
At idle, your psi should vary around 450-700psi, depending on what the pcm is calling for. With the ICP unplugged, the pcm cant see the sensor so it "defaults" to a know good setting but the scanner cant read it because its unplugged.
SOLD
Lt.Dan is offline
post #8 of 8 (permalink) Old Yesterday, 09:52 PM Thread Starter
Adams260z's Avatar
Does anyone know the resistance the IPR coil should have? Measured and was getting 1.2k Ohms drop over it.
'14 Jeep GC SRT
'79 Yamaha XS1100
