2002 7.3 dead pedal - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 07-09-2019, 10:30 PM Thread Starter
2002 7.3 dead pedal
7.3 dead pedal no gauges replaced pedal and overdrive shift lever still no pedal.
Now what do I do? tried to search it but no luck.
ford40 is offline
post #2 of 8 (permalink) Old 07-09-2019, 11:34 PM Thread Starter
Re: 2002 7.3 dead pedal
Oh and no blown fuses
ford40 is offline
post #3 of 8 (permalink) Old 07-10-2019, 02:10 PM
What do you mean by no pedal? Which pedal?
nsfr1206 is offline
post #4 of 8 (permalink) Old 07-10-2019, 03:06 PM Thread Starter
Sorry about that . throttle pedal . Truck just idles will not rev up.
ford40 is offline
post #5 of 8 (permalink) Old 07-12-2019, 04:43 AM
Had that to happen to my '99 in extremely cold weather but worked after warming up. Replaced the PCM relay and it never came back???
680 Puller is offline
post #6 of 8 (permalink) Old 07-12-2019, 04:39 PM
Moderator
Sbluke55's Avatar
Usually there is a short in the shifter column for the overdrive button. There should be a blown fuse somewhere.
01 f-250, Standard
Sbluke55 is offline
post #7 of 8 (permalink) Old 07-12-2019, 08:54 PM
I know you replaced the pedal assembly, how did the harness look? Recheck the harness including all the pins. Was it a OEM or aftermarket pedal assembly? Any codes? A bi-directional scan tool is you best friend.
Tomlin is offline
post #8 of 8 (permalink) Old Yesterday, 10:57 PM
Exactly, it's a classic case. Here's a link showing how to fix it, also on your 2002 it will be fuse #45, I know you said no blown fuses but they can be easy to miss. I caught mine in the early stages before the fuse blew, (I was having OD button problems) and replaced the shifter and harness, the hole in the insulation was so tiny I almost didn't see it but I'll guarantee you it's there.:
https://docs.google.com/viewer?a=v&p...M2Q5YjdmODQ4NQ
2002 F 350 4x4 CREW 164K, Isspro boost, tranny, pyro, FP, Hpo, coolant filter, Dieselsite tranny filter, AIS intake, ITP pre pump mod, 6.0 tranny cooler, AE & Torque Pro.
bigb is offline
