No Crank No Start - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 06-20-2019, 07:53 PM Thread Starter
No Crank No Start
Looked but can't find for no crank no start.
2003 F-350 7.3 Auto 4x4.
Parked a few days ago all was ok, went to go to town no crank no start. Turn key dash lights radio plays ,etc. tried in park and neutral-nothing. Batteries @13+ volts. Did notice antifreeze is way low.
Any suggestions as what to check, relays fuse?????
Thanks
JT
jterr is offline
post #2 of 4 (permalink) Old 06-20-2019, 10:08 PM
Re: No Crank No Start
Starter
Sent from my SM-G975U using Tapatalk
tda271 is offline
post #3 of 4 (permalink) Old 06-20-2019, 11:03 PM Thread Starter
I kept screwing around and have determined it is in the steering column;as in key or ignition switch.
Thanks
jterr is offline
post #4 of 4 (permalink) Old 06-25-2019, 01:38 AM
There is a small.hole just under the key cylinder. With the key I, stick a pick or small screwdriver in the hole and rotate the key. The whole cylinder will come out. Super easy to reply
9755mh is offline
