vibration, like driving on a rumblestrip - Page 2 - PowerStrokeNation : Ford Powerstroke Diesel Forum
 7Likes
post #11 of 19 (permalink) Old 05-12-2019, 04:55 AM
Moderator
Sbluke55's Avatar
Re: vibration, like driving on a rumblestrip
What happens when you lock the hubs in and leave the t case in 2wd
01 f-250, Standard
Sbluke55 is offline
post #12 of 19 (permalink) Old 05-12-2019, 12:13 PM Thread Starter
I don't know. I never tried that. I do know the 4WD is functioning normally. I've had to use that a few times since the vibration issue started.
mulerider is offline
post #13 of 19 (permalink) Old 05-13-2019, 01:35 AM
Moderator
Sbluke55's Avatar
Try that out. If it stops. Those bearings are bad. They are inside of the unit bearings.
mulerider likes this.
01 f-250, Standard
Sbluke55 is offline
post #14 of 19 (permalink) Old 05-17-2019, 01:18 AM
Has anyone checked the carrier bearing and rubber around it. i.e. The bearing might be okay, but if the rubber mount is worn or cracked, it can cause similar symptoms. Engaging 4wd might tighten-up the driveline just enough to disguise it.
2000 F250 Lariat, SCLB, 189k miles, RWD 3.73 LS, APCM
Chairman is offline
post #15 of 19 (permalink) Old 05-17-2019, 01:24 PM
Have you checked your u joints? I had one that was sticking and would vibrate sometimes when not engaged, but in 4wd it was forced to turn so it wouldn't vibrate
Sent from my SM-G975U using Tapatalk
tda271 is offline
post #16 of 19 (permalink) Old 05-17-2019, 09:59 PM Thread Starter
Mechanic called. Said they found nothing wrong with the rear end as mechanic #3 said. Nor did he find a problem with the output shaft of the transmission as he's thought. But did find bad bearings in the front end. I had a bad phone signal when he called. So, didn't get any more than that. He's replaced the bearing but had not test driven it yet to make sure that resolved the problem.
post #17 of 19 (permalink) Old 05-24-2019, 02:58 PM Thread Starter
You were right, it was the bearings. Truck is going great now. 6 months a 3 mechanics later.
Sbluke55 and longjonsilver like this.
post #18 of 19 (permalink) Old 05-25-2019, 02:15 AM
Moderator
Sbluke55's Avatar
Glad you got it fixed.
01 f-250, Standard
Sbluke55 is offline
post #19 of 19 (permalink) Old 05-25-2019, 06:48 PM
s10mike's Avatar
Hopefully your mechanic used good unit bearings or you will be doing it again soon
410customs likes this.
s10mike is offline
Similar Threads
clunking / vibration under feet when driving. bdemutis 7.3L Power Stroke Technical Info 10 08-03-2015 04:17 PM
acts like at wot randomly while driving 2000ford 7.3L Power Stroke Technical Info 2 04-16-2015 07:34 PM
Vibration when torque converter is locked. Seems like an engine miss. 97_f250_7.3L 6.0L Power Stroke Technical Info 15 04-26-2013 04:00 AM
Driving BAM STALLS, turn off, turn on, start, driving stalls Michael5126 1994-1997 Power Stroke Technical Info 10 02-05-2013 06:51 PM
Feels like im driving on a washboard?? ford4life76 Suspension and Drivetrain 3 08-17-2012 10:27 PM
