2003 f-250 window help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 04-18-2019, 01:35 PM Thread Starter
Jaybird14's Avatar
Hello I have a f-250 2003 crew xlt my issue is my driver side window switches work on every window but passenger front. The ones in the rear doors work solo up and down passenger door only works by rolling down will not roll up as for driver passenger switch. Rear door switch works properly removed put in front to try with new window motor and same issue only rolls down won’t go up. I’m lost any help is appreciated thanks guys. Also neither passenger or driver door locks work either and replaced both door switches.
Jaybird14 is offline
post #2 of 10 (permalink) Old 04-18-2019, 03:01 PM
Native Texan
masakimm's Avatar
Garage
Re: 2003 f-250 window help
I would start by checking the wiring where it goes from the body to the door. Start on drivers door but also check the passenger door. I see many issues with broken wires on vehicles between door and body.
Give it to Mikey. He won't eat it he hates everything. Hey Mikey!! He Likes It.
Upgrades:
masakimm is offline
post #3 of 10 (permalink) Old 04-18-2019, 05:42 PM Thread Starter
Jaybird14's Avatar
I did that had two split wire one to the speaker another in the harness still same issue.
post #4 of 10 (permalink) Old 04-18-2019, 05:49 PM Thread Starter
Jaybird14's Avatar
Here is a pic of what I found
File Type: jpeg CDB2F85C-3DA7-4DA6-8091-B07B0E67CFC6_1555609722737.jpeg (763.0 KB, 22 views)
File Type: jpeg 4487D10E-1554-4331-A082-04AF511F3CF1_1555609743423.jpeg (543.0 KB, 21 views)
post #5 of 10 (permalink) Old 04-18-2019, 05:52 PM
alleged moderator
tjctransport's Avatar
if the window works properly with the passenger side switch, i would say the issue in in the driver door passenger window switch.
simply put the driver door switch is not reversing power to let the window roll up.
as far as the power locks go, my bet is the lock actuators are bad. i had to replace the actuators in my 02 when i got it 11 years ago.
tom
tjctransport is offline
post #6 of 10 (permalink) Old 04-19-2019, 03:00 AM Thread Starter
Jaybird14's Avatar
No both switches only roll the window down will not go back up and now I keep wondering why my batts are dead my dome light doesn’t turn off 🤯
post #7 of 10 (permalink) Old 04-19-2019, 10:00 AM
alleged moderator
oh, ok. the window works by reversing power to the motor. the wires from the driver door to passenger window motor are also the power wires for the passenger side switch.
the white/yellow is one of the power wires feeding the passenger side switch, the other is tan/lite blue. then going to the motor itself from the passenger switch should be yellow/red and red/yellow
tom
post #8 of 10 (permalink) Old 04-19-2019, 03:00 PM Thread Starter
Jaybird14's Avatar
spliced in the wires that were cut but still no action same issue and now left side speaker won’t even come on
post #9 of 10 (permalink) Old 04-20-2019, 11:54 AM
don't play well w others
Dustybumpers's Avatar
Wires are damaged where they go in the driver's door.
Charlie
"A common mistake people make when trying to design something completely fool proof, is to underestimate the ingenuity of a complete fool."
Dustybumpers is offline
post #10 of 10 (permalink) Old 04-20-2019, 12:42 PM
scottu5
scottu5's Avatar
What he said. I spent weeks chasing exact same problems you had. Cleaning switches, checking pins... Turned out wire broken in harness door to cab on drivers side. You have to pull covering back and check all the wires one at a time. PITA, but you will find it 👍
'97 F250 7.3, crew cab, long bed, 4x4.
Trans cooler, Ext trans filter, Turbo 1.00 housing, KC S300 turb whl-360 bearing, RR 4x4 comp whl, FF stg1 (160/0),
Fuga E-Fuel, TSchp-FF tune, 3" dwnp-4"exh, NON EBPV pedstl, SB CAI, auto
“Always stand on principle even if you stand alone”
― John Adams
scottu5 is offline
Similar Threads
need help guy 2003 f-250 turbo pedistal tatertot 6.0L Power Stroke - Aftermarket & Performance 0 04-11-2012 01:21 AM
