Driver brake light and cruise not working. - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
post #1 of 4 (permalink) Old 04-17-2019, 01:16 AM Thread Starter
Village Idiot
x225x's Avatar
My rear driver brake light just quit working, and then discovered that my cruise control isnít either.
I replaced the turn signal switch, and still nothing. I also ordered another turn signal switch from Rockauto thatís a Motorcraft direct replacement. So we will see if that helps.
I replaced the bulb, checked the socket by using the passenger one. All fuses are OK.
Itís on a 2000 e350.
Any ideas? I might order a power probe to check it out further before I have to pay a shop to look at it.
2000 Ford E-350 4x4 Moto Van
x225x is offline
post #2 of 4 (permalink) Old 04-17-2019, 09:15 AM
alleged moderator
tjctransport's Avatar
Re: Driver brake light and cruise not working.
cruise is not working because the brake light is not working.
probably a broken wire somewhere if the bulb is good.
tom
tjctransport is offline
post #3 of 4 (permalink) Old 04-18-2019, 06:17 AM
Philhan69@aol.com's Avatar
I had a fuse under the hood that was blown.
Sent from my SM-G955U using Tapatalk
x225x likes this.
post #4 of 4 (permalink) Old 04-21-2019, 04:07 AM
Howís the third brake light? caused me problems on my Excursion.
j-winship is offline
Similar Threads
third brake light, dome light, door unlock not working. smashman511 1994-1997 Power Stroke Technical Info 6 03-14-2018 05:46 PM
97 Powerstroke Brake Lights and Third Brake Light Not Working Adinas95 1994-1997 Power Stroke Technical Info 13 02-19-2013 05:57 PM
Speedo and Cruise not working mleg1972 7.3L Power Stroke Technical Info 5 03-30-2011 12:22 AM
Cruise control, horn both not working and air bag light is on??? Jolo170 7.3L Power Stroke Technical Info 4 05-09-2010 01:22 AM
cruise control and backup lights not working JohnDeere9610 1994-1997 Power Stroke Technical Info 3 11-23-2008 08:32 AM
