Ok at wits end been watching videos an reading for the last 4 days - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 04-15-2019, 01:12 AM Thread Starter
Natdog's Avatar
Ok for the last several days I've changed the ipr,icp,cam sensor,ebp sensor changed out a bad injector and I'm still having rough idle times when it wouldn't start just free turn like it wasn't firing no smoke out the exhaust then went to pull out change gears and like I cut the switch off died towed it back after sitting a day it crunk back up still idled rough but had good power had a call for a tow was going down the Hwy for a couple miles an like I let off the pedal an lighly pressing the brake but didn't an wasn't I slowed to a stop and it cut off to not start back any help I'm stuck gonna take it to a mechanic if I can't figure something out quickly it's how I make a living(tow truck)
Natdog is offline
post #2 of 5 (permalink) Old 04-15-2019, 02:43 AM Thread Starter
Natdog's Avatar
By the way forgot to say it's a 1995 super duty f-450
Natdog is offline
post #3 of 5 (permalink) Old 04-15-2019, 12:19 PM
Moderator
Sbluke55's Avatar
Re: Ok at wits end been watching videos an reading for the last 4 days
So you need some way of monitoring the truck. Google "superduty diagnosis on the cheap". It shows you how to use forscan and torque pro to monitor and test your truck. You wont figure it out without seeing what the computer sees.
01 f-250, Standard
Sbluke55 is offline
post #4 of 5 (permalink) Old 04-16-2019, 02:44 PM Thread Starter
Natdog's Avatar
Ya I'm not Sure but I think I might have figured it out I'll know for sure in a couple days hopefully but the #22 fuse for the pcm has no power going in or coming out so I'm hoping it's a bad wire
Natdog is offline
post #5 of 5 (permalink) Old 04-19-2019, 12:25 PM Thread Starter
Natdog's Avatar
Ok figured it out hpop
Natdog is offline
Similar Threads
At my wits end - modded IDM and codes running issues Shaw 7.3L Power Stroke Technical Info 17 06-09-2010 04:19 AM
At wits end Warhippie 7.3L Power Stroke Technical Info 6 03-28-2010 11:02 PM
I'm at wits end with this truck... Mdub707 6.0L Power Stroke Technical Info 22 06-19-2009 05:42 PM
I am at my wits end dalpilot 6.0L Power Stroke - Aftermarket & Performance 18 06-22-2008 12:36 AM
Wits End lildevil02 General Questions & Discussion 16 11-01-2007 07:51 PM
