Dropped nut into the intake - PowerStrokeNation : Ford Powerstroke Diesel Forum
 4Likes
  • 3 Post By Dustybumpers
  • 1 Post By jamiesaun
post #1 of 8 (permalink) Old 04-12-2019, 01:49 PM Thread Starter
Unhappy Dropped nut into the intake
Hi, new to this forum. Did something so stupid. I had the spider out and both opening to the intake on the heads open. While taking the clamp that holds the muffler out, I dropped the nut of the clamp into the intake opening on the passenger. I have been trying to fish it out with a magnet with no luck. There is a passage that is smack in the middle of the hole that goes into the motor, I assume that the nut rolled deep. What should I do if I can's fish it out. Take the head off? Please help.
2000 F350 7.3 Powerstroke 4x4 Auto Transmission
Dillon123 is offline
post #2 of 8 (permalink) Old 04-12-2019, 02:09 PM
Moderator
Sbluke55's Avatar
Re: Dropped nut into the intake
Make sure it 100% went down the intake. It could of ended up in the valley. Next step would to pull the plenum, its bolt down and sealed with rtv. Once it's off it will be easier to pull out.
01 f-250, Standard
Sbluke55 is offline
post #3 of 8 (permalink) Old 04-12-2019, 02:22 PM Thread Starter
I will take off the plenum. My fear is that right in the Middle of the intake hole there is a channel that goes down into the motor. I heard it roll for a bit as if it rolled straight down that channel. If that is the case, what's next?
post #4 of 8 (permalink) Old 04-12-2019, 02:49 PM
Moderator
Sbluke55's Avatar
The only thing left would to pull the head. But I think the chances that it made it past the intake valve is slim to none.
What are you sing to try and fish it out?
01 f-250, Standard
Sbluke55 is offline
post #5 of 8 (permalink) Old 04-12-2019, 03:36 PM Thread Starter
I just bought a flexible magnet to stick in the hole. I also ordered a Autel Camera to see if I locate it. Man, I was doing all kinds of upgrades to this Truck and this happened! A 20 cent nut can potentially void all the work and money I spend on this rig.
post #6 of 8 (permalink) Old 04-12-2019, 03:40 PM
don't play well w others
Dustybumpers's Avatar
I would invest in a cheap borescope from harbor freight.
stick it in there, find the nut.
come back out, tape the magnet to the borescope, go back in and snatch it
s10mike, Sbluke55 and HilhavenFarm like this.
Charlie
"A common mistake people make when trying to design something completely fool proof, is to underestimate the ingenuity of a complete fool like me."
Dustybumpers is offline
post #7 of 8 (permalink) Old 04-13-2019, 12:45 AM
Master BS'er
jamiesaun's Avatar
Man, that's a really good idea.
I would have pulled it apart already.
Dustybumpers likes this.
Brother James
Ps...Im pretty frickin awesome!
jamiesaun is offline
post #8 of 8 (permalink) Old 04-13-2019, 01:16 AM
You wouldn't believe how many big issues that $49.99 gem has saved me on.
Charlie
Similar Threads
dropped brass fitting into head nick0360 6.0L Power Stroke Technical Info 10 02-19-2012 05:44 PM
Dropped torx bit into oil passage... Help please??? amclea01 6.0L Power Stroke Technical Info 17 10-13-2011 01:57 AM
Dropped clip into intake port Intrnlstorm 6.0L Power Stroke Technical Info 11 08-17-2011 01:08 AM
Hummm Dropped the pan today and... CSIPSD Transmission Related 16 01-19-2008 08:15 PM
Dropped in to say Hidee bigbluthunder New To The Nation 2 07-30-2007 07:43 PM
