E99 7.3 smokes after warming up - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 03-04-2019, 11:34 PM Thread Starter
CAT lover
Robertl211's Avatar
My buddy has a e99 7.3 that has had a hard life but it still runs like a top and is great to drive. It smokes like crazy once it warms up!! Doesn’t smoke when it’s cold. Goes through about a quart of oil/week. It’s dripping down the stack and is obviously going right out the exhaust. I suggested the turbo seals are probably junk and we should rebuild it, does anyone have any other ideas?
96 F250 RCFB 4x4 7.3
96 f350 CCLB Dually ZF5, custom flatbed, Gregio Medio Lamborghini paint, 3" dp 4" MBRP exhaust
95 F250 RCLB 7.3 4x4 conversion with 5" Sky RSK, D60 front, 18" American Racing, 35" Nittos, DIY SD intercooler, Melling LPOP, DIY 6637, Baby Swamps with TS6 and Swamps tunes, boost pyro trans
05 F350 RCLB Dually SOLD
Robertl211 is offline
post #2 of 4 (permalink) Old 03-05-2019, 01:28 AM
2000f250's Avatar
Re: E99 7.3 smokes after warming up
Turbo seals are real bad pull and rebuild. Or have rebuilt. KC turbo sells a upgrade/ rebuild kit you could buy.
2000f250 is offline
post #3 of 4 (permalink) Old 03-05-2019, 04:16 PM Thread Starter
CAT lover
Robertl211's Avatar
Does it make any sense to replace the cartridge? Or is the KC rebuild/upgrade kit the best option?
What is difficult about rebuilding the turbo? Seals hard to get seated right or are we just worried about the longevity of the rebuilt unit?
post #4 of 4 (permalink) Old 03-05-2019, 04:42 PM
2000f250's Avatar
You could just replace the center section I think Riffraff diesel has them . I have never rebuilt one I just saw that KC turbo sells a rebuild kit that is a upgrade from the stock turbo. A stock turbo is a 270 degree thrust bearing a upgrade would be a 360 degree thrust bearing or a ball bearing turbo is a great upgrade. I been looking at a kc38r for my rig to replace my GTP38R If your not comfortable rebuilding your self then I buy a rebuilt turbo or send his out to get rebuilt. IMG_0142.jpgIMG_0141.jpg
2000f250 is offline
Similar Threads
Surging while engine is warming up. Turboegt 7.3L Power Stroke Technical Info 4 12-06-2017 11:32 PM
no more high idle when warming up hdf3502005 General Questions & Discussion 4 09-27-2011 04:11 PM
not warming up solrac06 6.0L Power Stroke Technical Info 10 04-17-2011 01:23 PM
Powerstroke 7.3 no power after warming up xspire 1994-1997 Power Stroke Technical Info 22 08-19-2010 04:28 PM
