To all the no start people looking for info... - Page 4 - PowerStrokeNation : Ford Powerstroke Diesel Forum
 5Likes
post #31 of 33 (permalink) Old 10-30-2017, 09:01 PM
EA - Eggfarts Anonymous!
Turd-250's Avatar
Re: To all the no start people looking for info...
Originally Posted by mamacaldera View Post
help my husband work on trucks he is a diesel mechanic by trade and has never had such a headache of a truck... i have learned more about the then i have ever needed to know... and thanks for the quick repsonse
sure thing happy to help! but i think you'll need the rest of the guys to see this in your own thread. go here & click on the 'New Thread' button (upper left part of page): 7.3L Power Stroke Technical Info - PowerStrokeNation : Ford Powerstroke Diesel Forum
"Farts are like a good bourbon, add a small touch of water to bring out the excellence."
Turd-250 is offline
post #32 of 33 (permalink) Old 10-30-2017, 09:02 PM
Turd-250's Avatar
button looks like this:
Turd-250 is offline
post #33 of 33 (permalink) Old 04-16-2018, 04:10 AM
Maybe you could help me my 98 7.3 is doing my head in. Occasionally it will start and run and then just die like the key is turned off. Have tried swapping basically every sensor from another truck including idm and pcm. Purchased a AE scanner and it passes a buzz test and everything seems ok with ipr% and oil psi at injectors. When I run a koeo or koer (on the occasions it does start) it gets half way through the test and and the engine dies and scanner says unknown error same goes for koeo test. Have pulled injectors and shimmed poppets and replaced o rings. I will add that there is a enormous amount of blowby so assuming got a hole in piston or something but I don’t wanna rebuild the bastard until I can fix this problem!
Chip1986 is offline
