Cracked block serial # - Track some S/N's - Page 8 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #71 of 80 (permalink) Old 02-04-2011, 03:33 AM
Your Daddy
450ciPSD's Avatar
Re: Cracked block serial # - Track some S/N's
Any new info on this?
My original block died from cavitation by water contaminated Evans coolant. Ended up with a nice little hole in #8 cylinder wall.
What worries me is the guy that did the tuning on my chip(OP in this thread) is asking about cracked blocks.......
Any news David?
444 + .030 over = 450ci
2000 F250 Lariat 4x4
22yr US Navy MMC(SW)retired
450ciPSD is offline
post #72 of 80 (permalink) Old 04-09-2011, 09:03 PM
444CuiOBS's Avatar
Hey guys, does there seem to be a trend going with cracked blocks? Certain years or s/n ranges?
1997 Ford F250HD XLT SC, Tymar. Edge CS. Ford shim. DP to 4" straight. 140,000mi Cooper STT 305's Just finished cab/box off resto
444CuiOBS is offline
post #73 of 80 (permalink) Old 02-16-2012, 04:34 PM
1360660 Cracked passenger side from freeze plug to freeze plug and a 12" crack below it right above the oil pan. No contamination. I have Forged rods so I am going to try to fix it with locknstitch. JB Weld did not hold.
rishsd is offline
post #74 of 80 (permalink) Old 04-20-2012, 12:01 AM
Cracked mine about three weeks ago. Cracked from the #4 main bearing cap bolt hole down a casting seam all the way to the cam bearing. Engine build date is 12/24/97. Original engine with 94,000 miles on it! Never should have happened.
Curtsey
Early 99 Crew Cab,LB , 4" magna-flow exhaust, S&B Intake, FASS Pump, HRX, Regulated Return, Riff Raff Billet Plenums, ARP Studs, 910 springs, Chromoly Push rods, OBA, Carson Stuaffer t4 mount and a Borg warner s64.5 sxe Turbo, PIS 175/80's, T-500, ISSPRO EV2 Gauges, BTS Trans!
cjfarm11 is offline
post #75 of 80 (permalink) Old 05-12-2012, 06:43 AM
Whites Diesel Performance
Looks to me between 12/97 and 01 if im not right correct me. 12/96 and 11/97 both are fine and 97 has 308K
Gotta love the 90's lmao
'96 F250
FFD 350/200
BW SXE476
Dual HPOP
Gearhead Tunes
[email protected]
(12.69 @110 when it was a 5 spd)
96F350Kid is offline
post #76 of 80 (permalink) Old 03-04-2013, 02:03 PM
sorry guys, what's an OBS and can someone inform me about the cracking blocks? Is it prevelant in certain years? does it occurr on bone stock engines? Thanks much
7.3Cip is offline
post #77 of 80 (permalink) Old 04-27-2013, 05:31 PM
Joined cracked block club
Red 93 L1 #3383's Avatar
Just found my block cracked. Pulled the oil pan to fix an oil leak. #2 cam bearing was laying in the oil pan. Cracked from cam bore all the way down through webbing to pan rail. The motor still ran like a raped ape w/ 262,6xx miles on it. Good oil pressure, no overheating, no noises, HPOP would hit 2600 on the scan tool. Only problems are / were oil leak by oil filter ( resealed the cooler last weekend, didn't stop the leak ) & diesel in coolant ( did left 4 injector cups last weekend, was going to do the others this weekend). I guess it's time to find a new engine / truck. Depends on what I deciede there may be some stock e99 parts showing up in the classifieds.
Build date on valve cover 8-14-98
Serial number 809943
e99 F-350 Crew cab 4x4 auto 263k, '01 forged rod motor, bellowed up-pipes, 3.5" down pipe w/ 4" straight pipe, 6637 filter
Red 93 L1 #3383 is offline
post #78 of 80 (permalink) Old 05-04-2013, 05:59 AM
Upon further inspection the #3 cam bore has the same cracks as #2 just not quite as noticeable. I wonder how many miles I would have gotten out of it before it self-destructed.
post #79 of 80 (permalink) Old 03-22-2014, 10:31 PM
caseih_92's Avatar
im at work and cant check soooo build date is 4/01 :/ good or bad
-2001 7.3L f350 powerstroke sclb RUST FREE
4x4 offroad
Garrett GT38r turbo
soon to be twinned
fabtech pre runner bumper/ grille guard
4 hella 6" slimlines (2x 150w) (2x 100w)
-2001 Extended cab long bed 3500 Cummins 5.9 55k miles
8" Ozzy Dual Stacks.
leveled
35" goodyear mtrs
caseih_92 is offline
post #80 of 80 (permalink) Old 03-26-2014, 07:41 PM
Bobs 7.3
Bobs 7.3's Avatar
This tread is a year old lol I used to do that when I first got on here. Check the date the last posts was made before ya post as alot of these old posts (over 3 months) no one really posts on anymore.
Bobs 7.3 is offline
