cannot get obd2 to connect to pcm - PowerStrokeNation : Ford Powerstroke Diesel Forum
 5Likes
post #1 of 67 (permalink) Old 11-23-2013, 08:10 AM Thread Starter
richyrich's Avatar
I had a cheapo elm 327 that worked for a day or two then one day it wouldn't work. so I returned it and got a really good one its also a bluetooth but it will not connect to my pcm it just says (cannot communicate with ecu). I figured fuse 12 was blown but my cigar lighter and everything else works. it turns on like it has power and connects to my phone but no my pcm anyone have any ideas
2002
f-250 7.3L powerstroke superduty xlt sc sb 4x4 offroad, pure turbos 360 turbo rebuild kit,
mile marker 449 s/s hub locks, php phoenix 6 position chip, diy 6637 intake, 140k and rollin strong
richyrich is offline
post #2 of 67 (permalink) Old 11-23-2013, 10:24 AM
MSTR-P's Avatar
Re: cannot get obd2 to connect to pcm
Not sure what kind you bought, but there are quite a few OBDII scanners that don't work on our old trucks. If you are trying to trouble shoot, take what you bought back and buy the AE Ford bundle.
MSTR-P is offline
post #3 of 67 (permalink) Old 11-23-2013, 01:07 PM
Village Idiot
southmike's Avatar
Mine stopped working as well...I updated torque now it doesn't work.
It works on my kids cars to scan but is now a worthless ap.....
But the bigger question is will it work with ae.
I assume so but...
Maybe there is a battery issue. I know my hand held scanner did not like to read some cars with dead cells. Which is a possibility.
southmike is offline
post #4 of 67 (permalink) Old 11-23-2013, 06:42 PM
Demon Dually
speeddemon31176's Avatar
Most store bought scanners DO NOT work with the powerstroke engines. They are not true OBD2 systems. AE with Ford enhanced bundle definitely works with them as well as snapon and other high end scanners.
speeddemon31176 is offline
post #5 of 67 (permalink) Old 11-23-2013, 10:23 PM Thread Starter
richyrich's Avatar
I assume so but...
I had the exact same thing happen to me I updated and now it won't work I has one that worked fine then one day it just stopped communication with the pcm could it be the update
2002
post #6 of 67 (permalink) Old 11-23-2013, 10:25 PM Thread Starter
richyrich's Avatar
And I would get a snap on or an ae if I had the money and knew it would connect to my pcm. I don't really need it tho I only wanted it for the few guages it actually had. I may be getting a glow shift 3in1 as anyone used these and are they reliable
2002
post #7 of 67 (permalink) Old 11-24-2013, 03:17 AM
Village Idiot
southmike's Avatar
That is the exact thing that happend to me.
post #8 of 67 (permalink) Old 11-25-2013, 11:04 PM
Is the truck running fine, or does it not run? Usually, when a scan tool cannot communicate and the fuses are good, the PCM is likely to be the problem.
post #9 of 67 (permalink) Old 11-25-2013, 11:24 PM
I know when my truck wouldn't start just crank and I couldn't connect to the PCM/ obdII that my maxi fuse under the good for the PCM was blown. I believe it's fuse 24. That is assuming the truck won't start.
2000 F350 CCLB 7.3, 4x4 AT
Goatwrangler is offline
post #10 of 67 (permalink) Old 11-26-2013, 02:37 AM
Village Idiot
southmike's Avatar
I have to double check mine ..but I am 80% sure it is the torque ap itself. The next thing I want to try is wired cord.
