Anti-Freeze in Oil HELP - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 196 (permalink) Old 12-31-2008, 04:40 PM Thread Starter
The Fireman
big_stroker's Avatar
Ok just checked my oil... and yup there is anti freeze in there.
Please help me what caused this and how do i fix it
big_stroker is offline
post #2 of 196 (permalink) Old 12-31-2008, 04:41 PM
All done now
Arisley's Avatar
Re: Anti-Freeze in Oil HELP
Oil cooler is usually the place to start looking.
Arisley is offline
post #3 of 196 (permalink) Old 12-31-2008, 04:44 PM Thread Starter
The Fireman
What am i looking for? how can i tell if it is bad or not?
The truck is running fine just losing anti freeze into the oil
post #4 of 196 (permalink) Old 12-31-2008, 04:59 PM
THE ALASKAN's Avatar
If you look on the side of the motor it looks like a pringles potato chip can turned sideways I don't know how else to describe it.....
mmmm pringles....... Yes, I'm hungry.
Anyway, theres replaceable orings that seal the "can" to the end caps and it should fix you right up.
JIM
97 CC PSD 4x4 with a few things done to it- 13.2
97 x-cab PSD 4x4 with a few things done to it- 15.8
97 x-cab PSD 4x4 Tymar intake only
- forever
99 x-cab DRW 4x4 with a few things done to it- 14.9
60 Ford thoughts of putting a PSD into it
89 F150 thoughts of putting a PSD into it
01 Arctic Cat 300 4x4 Thoughts of putting a PSD into it
THE ALASKAN is offline
post #5 of 196 (permalink) Old 12-31-2008, 05:02 PM Thread Starter
The Fireman
so i just have to replace the o-rings in there
And can i drive it 2 miles to the shop where i work on my stuff?
And will i have to change the oil a few time?
post #6 of 196 (permalink) Old 12-31-2008, 05:06 PM
How bad is it?? Do you have gunk build up under your oil cap? Does your oil look like chocolate milk?? because everything in that motor uses that oil, Injectors, HPOP, IPR, ICP, bearings etc. etc. and the more it gunks up the harder it is to get out of the heads and misc parts. Now this is just my humble opinion but if its only 2 miles, I'd be calling a friend to tow me down or it would be worth the 50$ tow bill.
JIM
- forever
post #7 of 196 (permalink) Old 12-31-2008, 05:10 PM Thread Starter
The Fireman
no prob i will have dad tow me down there tomorrow to bad its a dodge (Work pays for it or it would be a ford) i will feel like crap the whole time he is pulling me tho
Is there any thing i should know or is it pretty simple ?
post #8 of 196 (permalink) Old 12-31-2008, 05:15 PM
It's not the easiest thing in the world to pull apart, another thing to consider that it might be a bad cooler. I'm unsure of a way to test them and maybe someone has a "trick" to that, but a new cooler is about 150 bucks plus core if I remember but that does not include the end caps. I'm at work and I don't have my Manuel with me or I could look it up for ya.
JIM
- forever
post #9 of 196 (permalink) Old 12-31-2008, 05:23 PM
fueled by Colecovision
golfer's Avatar
Garage
I've never seen coolant in the oil from a bad oil cooler. Usually the opposite. Oil in coolant.
The oil pressure is (nearly) always higher than the coolant pressure...so if the oil cooler is bad...then the oil will push its way through the "bad" o-rings on the cooler into the coolant.
Coolant in the oil is typically a head gasket failure.
and noting your other thread (white smoke @ idle, & coolant loss)...supports a probable head gasket failure.
You could do a fair bit of diagnostics OR you can change the oil cooler, but if the symptoms persist...I would be looking at the head gaskets.
take care~
Dave
golfer is offline
post #10 of 196 (permalink) Old 12-31-2008, 05:23 PM Thread Starter
The Fireman
Well im just going to get a new oil cooler and put on there... Where would the best place to get a new one. From the International dealer ?
