stock fuel pump/ fuel system? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 25 (permalink) Old 04-13-2011, 03:27 PM Thread Starter
Banning Smut
PTSUPERD's Avatar
At what level is it necessary to go to an aftermarket pump and make fuel system mods?
I'm looking to make ~ 500 rwhp....but want to keep everything as simple as possible making only neccessary mods..
PTSUPERD is offline
post #2 of 25 (permalink) Old 04-13-2011, 03:29 PM
Re: stock fuel pump/ fuel system?
when I did my 155's it was reccomended that I do a bigger fuel pump....
03 F-250 207000 miles, Mad Turbo Werks Stage 1 Turbo, RCD155 injectors 100% Nozzles, 150/180 FASS, FCDP EGR delete, ARP Headstuds, OEM head gaskets, Diesel Site coolant filter kit, SCT Tunes, Hellmans Sump, 4inch Magnaflow Exhaust, 6.4 banjo bolts, AR-9100 Oil Treatment, 58v FICM
F-250-Owner is offline
post #3 of 25 (permalink) Old 04-13-2011, 03:31 PM
aggie's Avatar
Some trucks will drop to 30psi w/ stock injectors, some hold 40+ w/ 190s. Stonepushers is holding 45-50 w/ 225s which ive never seen before. 190s is kind of a crap shoot, most trucks most likely not holding pressure. You definately want to watch the pressure as dropping pressure wears out injectors.
[SIGPIC][/SIGPIC]
aggie is offline
post #4 of 25 (permalink) Old 04-13-2011, 03:33 PM
bring the chain
kyle43335's Avatar
in saying you want to make 500rwhp,i would simply advise that you install a ad2. i like to do some fuel bowl modifications as well,to take the ad half in fuel line right to the bowl. then i also change the fitting and run 3/8 fuel line directly to the heads. i currently just finished one with a set of 200s and it holds 58 psi all the way to redline/full load. to answer your question alittle more direct. its directly nessesary to upgrade your fuel system once you move past stock injectors. hope this helps
kyle43335 is offline
post #5 of 25 (permalink) Old 04-13-2011, 03:37 PM Thread Starter
Banning Smut
PTSUPERD's Avatar
Thanks guys. I will NOT purchase another FASS...and I had an AD2 on my 7.3 that would not hold fuel pressure on my 300 CC hybrids. Airdog recommended running a Raptor pump with the AD2...
Now I'm not going anywhere near that big this time (155-170 ccs)...but I'm a bit gunshy still.
PTSUPERD is offline
post #6 of 25 (permalink) Old 04-13-2011, 03:42 PM
bring the chain
kyle43335's Avatar
you could always go full custom,like i did pm me if you would like pics of mine. my system holds 75 psi no matter what.
post #7 of 25 (permalink) Old 04-13-2011, 03:46 PM
Mpoage's Avatar
You will probly want to think about a sump as well so you dont have 1/4 tank issues.
2007 Ford F-250 Lariat Outlaw 4X4
SCT X3 Tuned By Innovative Diesel
Straight Piped
Edge Insight
Mpoage is offline
post #8 of 25 (permalink) Old 04-13-2011, 03:56 PM
I ran an AD-150 feeding my stock pump with 185's and it would drop 3-4psi on hard runs, but never below 53psi. I had the factory regulator removed from the upper fuel bowl, put a regulator in the return line, and got rid of the banjo bolts. Worked really good for me.
06 F-250 ECSB 4x4, 6.0 - sold - little
2010 F-250 CCSB 4x4 6.4 Lariat Ultimate-few mods, but it is FAST!!!!
fuekear is offline
post #9 of 25 (permalink) Old 04-13-2011, 03:59 PM Thread Starter
Banning Smut
PTSUPERD's Avatar
not bad...
I even thought of just running another stocker in tandem....regulated return is a good idea too...
PTSUPERD is offline
post #10 of 25 (permalink) Old 04-13-2011, 04:04 PM
I had the 1/4 tank issue with my stock pickup. When I installed the new draw straw I left some fuel in the tank, supported it where the straps go(plastic tanks sag), drilled holes centered on the straw length cut line(looks like a castle), and never had touble sucking air.
fuekear is offline
