water/meth? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 10-08-2010, 09:45 PM Thread Starter
icebob's Avatar
water/meth?
benn reading for the last 2 days about those, I definitely want one, my question is is there a big difference between the kit out there? The CoolingMist one is really attractive $ wise... should I stay away from it, and is the Snow stage 2 the only way to go? Thx in advance
05 F250 XLT
SCT with IDP tunes
Straight pipe
icebob is offline
post #2 of 8 (permalink) Old 10-08-2010, 11:52 PM
Sarcastic Bastard
Re: water/meth?
snow Stage 3, just no need for the MPG max part ( saves like $200 ). Get the big tank ( 7 gallon ). Thats what I run and love it. It cools my EGT on long mountain grades here.
Thanks Eric!
Thanks Doug!
Special thanks to Rich for helping me pick chargers for my newest mod!!
Cobra 19 & 54 is offline
post #3 of 8 (permalink) Old 10-09-2010, 04:12 AM
Re: water/meth?
6.0 is NOT a good motor for meth. with adding even more pressure in the cylinder you just asking for the head gasket to pop. If you put studs on your motor then the next thing I would worry about is the valves, meth tears them up. if your going to do it i really would run anything stronger than washer fluid.
strokinDa6.4 is offline
post #4 of 8 (permalink) Old 10-09-2010, 01:55 PM Thread Starter
icebob's Avatar
Re: water/meth?
I want to use it for cooling, I'm not looking for power
05 F250 XLT
SCT with IDP tunes
Straight pipe
icebob is offline
post #5 of 8 (permalink) Old 10-09-2010, 02:05 PM
you want some of this?
smorris's Avatar
Re: water/meth?
Some of the cheapo washer fluid is over 20% meth. You really cant know how much unless its on the bottle. I've looked and never saw any that show the %.
2000 f-350 cc lb dually 4x4, BTS transmission
[email protected] 90 mph on MT mud tires and 8,000 #
coming soon--97 cc lb 4x4
smorris is offline
post #6 of 8 (permalink) Old 10-09-2010, 02:08 PM
KT Performance's Avatar
Re: water/meth?
The Coolingmist systems are great kits. I'll be out of the office all weekend but if you have any questions about them, you can reach me on my cell.
Thanks,
Kenny
352-636-0812
KT Performance is offline
post #7 of 8 (permalink) Old 10-11-2010, 09:53 PM
Slated4Greatness's Avatar
Re: water/meth?
I have the Snow MPG kit and it is awesome!! I only run water and for cooling purposes. It has dropped temps 150 or so. I have (1) medium nozzle and (1) larger nozzle and the 7 gallon tank can be a little small for longer trips so I am having a 34 gallon custom tank built. It just happens to work out to that size for the area I am putting it in. A 10 gallon or larger tank is better IMHO.. Also the straps that hold the plastic 7 gallon tank in are a joke!!
2006 F350 Lariat Tow Boss W/training wheels.
SCT W/GH's tunes, ARP's, Blk & Heads milled, Strictly RR and aux coolant lines, 6" Aussies, Snow MPG-Max, BPD: VK688,EGR, W/Pump, and FICM, Coolant filt, Train Horns, CTS (Monitor only) + Autometer backups
RIP Muley 9-25-09
Keep on Honkin' Jerry 04-05-10
Slated4Greatness is offline
post #8 of 8 (permalink) Old 10-12-2010, 03:55 AM
Re: water/meth?
I have had Snow stage 3 on my 04 for three years now with no problems. For the most part I run straight water and sometimes washer fluid. I didn't put it on for extra power just for cooling. No studs, original gaskets, I am sure the coolant filter has helped with the original gaskets. I have a 16 gallon tank that seems to be just about right for longer trips in the mountains. I can generally make it out and back with needing to refill.
F350R is offline
